阅读:2908回复:0
利用RamdonAccessFile来实现文件的追加
更多 发布于:2011-09-01 02:13
 RamdonAccessFile 是个很好用的类,功能十分强大,可以利用它的length()和seek()方法来轻松实现文件的追加,相信我下面这个例子是很容易看懂的,先写入十行,用length()读出长度(以byte为单位),在用seek()移动到文件末尾,继续添加,最后显示记录。
import java.io.*;
public class iostreamDemo {
 public static void main(String[] args) {
  try{
   RandomAccessFile rf1 = new RandomAccessFile("d:\\jeru.txt","rw");
   for (int i = 0; i < 10; i ++ ) {
    rf1.writeBytes("xixi,this is line "+i+"\n");
   rf1.close();
   int i = 0;
   String record = new String();
   RandomAccessFile rf2 = new RandomAccessFile("d:\\jeru.txt","rw");
   rf2.seek(rf2.length());
   rf2.writeBytes("lala,append line"+"\n");
   rf2.close();
   RandomAccessFile rf3 = new RandomAccessFile("d:\\jeru.txt","r");
   while ((record = rf3.readLine()) != null) {
    i ++;
    System.out.println("Value "+i+":"+record);
   rf3.close();
  }catch(Exception e){}
