schack8888
风云使者
风云使者
  • 注册日期2010-12-06
  • 发帖数686
  • 火币3641枚
  • 粉丝161
  • 关注102
阅读:5328回复:0
[汇编源码]DOS6.0源程序中的硬盘引导记录源程序FDBOOT.ASM
更多 发布于:2011-10-23 17:01
; * Microsoft Confidential
; * Copyright (C) Microsoft Corporation 1983 - 1991
; * All Rights Reserved.
; BOOT - IBM hard disk boot record 6/8/82
; This is the standard boot record that will be shipped on all hard disks. It contains:
; 1. Code to load (and give control to) the boot record for 1 of 4 possible
; operating systems.
; 2. A partition table at the end of the boot record, followed by the required signature.
_data segment public
assume cs:_data,ds:_data
org 600h
cli ;no interrupts for now
xor ax,ax
mov ss,ax
mov sp,7c00h ;new stack at 0:7c00
mov si,sp ;where this boot record starts - 0:7c00
push ax
pop es ;seg regs the same
push ax
pop ds
sti ;interrupts ok now
cld
mov di,0600h ;where to relocate this boot record to
mov cx,100h
repnz movsw ;relocate to 0:0600
; jmp entry2
db 0eah
dw $+4,0
entry2:
mov si,offset tab ;partition table
mov bl,4 ;number of table entries
next:
cmp byte ptr[si],80h ;is this a bootable entry?
je boot ;yes
cmp byte ptr[si],0 ;no, is boot indicator zero?
jne bad ;no, it must be x"00" or x"80" to be valid
add si,16 ;yes, go to next entry
dec bl
jnz next
int 18h ;no bootable entries - go to rom basic
boot:
mov dx,[si] ;head and drive to boot from
mov cx,[si+2] ;cyl, sector to boot from
mov bp,si ;save table entry address to pass to partition boot record
next1:
add si,16 ;next table entry
dec bl ;# entries left
jz tabok ;all entries look ok
cmp byte ptr[si],0 ;all remaining entries should begin with zero
je next1 ;this one is ok
bad:
mov si,offset m1 ;oops - found a non-zero entry - the table is bad
msg:
lodsb ;get a message character
cmp al,0
je hold
push si
mov bx,7
mov ah,14
int 10h ;and display it
pop si
jmp msg ;do the entire message
hold: jmp hold ;spin here - nothing more to do
tabok:
mov di,5 ;retry count
rdboot:
mov bx,7c00h ;where to read system boot record
mov ax,0201h ;read 1 sector
push di
int 13h ;get the boot record
pop di
jnc goboot ;successful - now give it control
xor ax,ax ;had an error, so
int 13h ;recalibrate
dec di ;reduce retry count
jnz rdboot ;if retry count above zero, go retry
mov si,offset m2 ;all retries done - permanent error - point to message,
jmp msg ;go display message and loop
goboot:
mov si,offset m3 ;prepare for invalid boot record
mov di,07dfeh
cmp word ptr [di],0aa55h ;does the boot record have the
; required signature?
jne msg ;no, display invalid system boot record message
mov si,bp ;yes, pass partition table entry address
db 0eah
dw 7c00h,0
include fdisk5.cl1
org 7beh
tab: ;partition table
dw 0,0 ;partition 1 begin
dw 0,0 ;partition 1 end
dw 0,0 ;partition 1 relative sector (low, high parts)
dw 0,0 ;partition 1 # of sectors (low, high parts)
dw 0,0 ;partition 2 begin
dw 0,0 ;partition 2 end
dw 0,0 ;partition 2 relative sector
dw 0,0 ;partition 2 # of sectors
dw 0,0 ;partition 3 begin
dw 0,0 ;partition 3 end
dw 0,0 ;partition 3 relative sector
dw 0,0 ;partition 3 # of sectors
dw 0,0 ;partition 4 begin
dw 0,0 ;partition 4 end
dw 0,0 ;partition 4 relative sector
dw 0,0 ;partition 4 # of sectors
signa db 55h,0aah ;signature
_data ends
end
兼职版主
