阅读:2059回复:0
Python防止ddos 攻击
更多 发布于:2011-10-23 21:13
这个周末叫一个烦啊,网站突然打不开了,赶紧的远程连上去看看是啥问题 结果悲剧了,ssh连不上去,总是超时 第一反应就是被ddos了
联系机房结果说流量占满了,更悲剧的是这个机房竟然没有硬件防火墙,没有办法只能跑去机房看看找下IP了
结果一查不得了啊,满屏的连接,唯有先断网查查几个访问比较多的IP
不过这治标不治本的方法只能维持很短时间,没过多久就又不行了,没有硬件防火墙的机房伤不起啊 不过周末机房都不给安排上架,也就不能换机房了,只好先就那样挂着吧
网上有关ddos的攻击说的很详细了,不过在没有硬件防火墙的情况下要防住还真是件麻烦事,就想写个脚本 检测固定时间内的指定IP的请求数,把疑似攻击的源用iptables禁止掉 无意见看到 防DDoS脚本in python
from subprocess import Popen,PIPE
import re
import time
import sqlite3
CONCURRENCY_ALLOWED = 30
OUTDATE_TIME = 86400
# initializing database
db = sqlite3.connect("/tmp/ddos.db3")
c = db.cursor()
try:
   c.execute("create table ddos (ip text unique,date integer);")
except:
   print "database exists"
# blocking ips has more than CONCURRENCY_ALLOWED connections
pipe = Popen("netstat -ntu | awk '{print $5}' | cut -d: -f1 | sort | uniq -c | sort -n >
            /tmp/ddos.txt",shell=True,bufsize=1024,stdout=PIPE).stdout
#ddos = pipe.read()
ddos = open("/tmp/ddos.txt").read()
ct = re.compile(r"(S+)s+(S+).*n").findall(ddos)
for count,ip in ct:
   if int(count)>CONCURRENCY_ALLOWED and (ip != "127.0.0.1") and (not ip.startswith("192.168")):
       out = Popen("iptables -I INPUT -s %s -j DROP"%ip,shell=True,bufsize=1024,stdout=PIPE).stdout
       print "blocking %s for %s visits" % (ip,count)
       c.execute('replace into ddos values (?,?)',(ip,int(time.time())))
       time.sleep(0.1)
db.commit()
# unblocking outdated blockings
c.execute("select * from ddos")
ddos = c.fetchall()
for ip,date in ddos:
   if date + OUTDATE_TIME < time.time():
       c.execute("delete from ddos where ip=?",(ip,))
       print "unblocking %s" % ip
       out = Popen("iptables -D INPUT -s %s -j DROP"%ip,shell=True,
       time.sleep(0.1)
db.commit()
