阅读:5208回复:0
[汇编源码]汇编源码--basload
更多 发布于:2011-10-26 09:22
[pre]
;BASLOAD.ASM      07/09/84 - DKeels;----------------------------------------------------------------------------;This program provides BASIC programs with access to the program loader (LOAD) ;by passing parameters via the system parameter area (SYSPARM).;;Inputs:;  FILE SPEC 1    - A string (len <= 80) with the complete name, including;          path, of the file to be loaded and executed.;          Example: 'MAINMENU.EXE' or 'C:\FORMAT.COM';  PARAMETER 1  - A string (len <= 80) with the command line parameters;          to be passed to the program specified in FILE SPEC 1.;          Example: '' or 'A:';  FILE SPEC 2  - Same as 1.;  PARAMETER 2  - Same as 1.;;Outputs:;  This program gives control to LOAD.;----------------------------------------------------------------------------CODE        SEGMENT 'CODE'        ASSUME    CS:CODE        PUBLIC    BASLOAD        ;make known to BASIC at link timeBASLOAD        PROC    FAR    ;prologue        PUSH    BP        ;save BP        MOV    BP,SP        ;set base for parm list        PUSH    DS        ;DS -> basic work area        PUSH    ES        ;ES -> basic work area        MOV    DX,'dk'        ;interrupt verification switch        INT    77H        ;get seg address of sysparm area in AX        MOV    ES,AX        ;ES -> sysparm area        CLD            ;set direction for all moves    ;move file spec 1 to sysparm        MOV    BX,SS:[BP+12]    ;get addr of string descriptor        MOV    CX,DS:[BX]    ;get length of string into CX        MOV    SI,DS:[BX+2]    ;get addr of string into SI        MOV    DI,0        ;offset into sysparm        REP    MOVSB        ;move string        MOV    BYTE PTR ES:[DI],0    ;make it asciiz string    ;move parameter 1 to sysparm        MOV    BX,SS:[BP+10]    ;get addr of string descriptor        MOV    CX,DS:[BX]    ;get length of string into CX        MOV    SI,DS:[BX+2]    ;get addr of string into SI        MOV    DI,81        ;offset into sysparm        INC    CL        ;adjust for cr to be added at end        MOV    BYTE PTR ES:[DI],CL    ;1st byte is length of string        DEC    CL        ;re-adjust for move operation        INC    DI        REP    MOVSB        ;move string        MOV    BYTE PTR ES:[DI],13    ;add cr to end    ;move file spec 2 to sysparm        MOV    BX,SS:[BP+8]    ;get addr of string descriptor        MOV    CX,DS:[BX]    ;get length of string into CX        MOV    SI,DS:[BX+2]    ;get addr of string into SI        MOV    DI,163        ;offset into sysparm        REP    MOVSB        ;move string        MOV    BYTE PTR ES:[DI],0    ;make it asciiz string    ;move parameter 2 to sysparm        MOV    BX,SS:[BP+6]    ;get addr of string descriptor        MOV    CX,DS:[BX]    ;get length of string into CX        MOV    SI,DS:[BX+2]    ;get addr of string into SI        MOV    DI,244        ;offset into sysparm        INC    CL        ;adjust for cr to be added at end        MOV    BYTE PTR ES:[DI],CL    ;1st byte is length of string        DEC    CL        ;re-adjust for move operation        INC    DI        REP    MOVSB        ;move string        MOV    BYTE PTR ES:[DI],13    ;add cr to end    ;exit to BASIC        POP    ES        POP    DS        POP    BP        RET    8BASLOAD        ENDPCODE        ENDS        END    BASLOAD
[/pre]
