阅读:8051回复:3
C语言库函数代码大全
更多 发布于:2011-10-29 22:47
O类字母
     函数名: open
功   能: 打开一个文件用于读或写
用   法: int open(char *pathname, int access[, int permiss]);
程序例:
#include <string.h>
#include <stdio.h>
#include <fcntl.h>
#include <io.h>
int main(void)
   int handle;
   char msg[] = "Hello world";
  if ((handle = open("TEST.$$$", O_CREAT | O_TEXT)) == -1)
       perror("Error:");
       return 1;
   write(handle, msg, strlen(msg));
   close(handle);
   return 0;
函数名: outport
功   能: 输出整数到硬件端口中
用   法: void outport(int port, int value);
程序例:
#include <stdio.h>
#include <dos.h>
int main(void)
   int value = 64;
   int port = 0;
  outportb(port, value);
   printf("Value %d sent to port number %d\n", value, port);
   return 0;
函数名: outportb
功   能: 输出字节到硬件端口中
用   法: void outportb(int port, char byte);
程序例:
#include <stdio.h>
#include <dos.h>
int main(void)
   int value = 64;
   int port = 0;
   return 0;
函数名: outtext
功   能: 在视区显示一个字符串
用   法: void far outtext(char far *textstring);
程序例:
#include <graphics.h>
#include <stdlib.h>
#include <stdio.h>
#include <conio.h>
int main(void)
   /* request auto detection */
   int gdriver = DETECT, gmode, errorcode;
   int midx, midy;
  /* initialize graphics and local variables */
   initgraph(;gdriver, ;gmode, "");
  /* read result of initialization */
   errorcode = graphresult();
   if (errorcode != grOk)   /* an error occurred */
       printf("Graphics error: %s\n", grapherrormsg(errorcode));
       printf("Press any key to halt:");
       getch();
       exit(1); /* terminate with an error code */
  midx = getmaxx() / 2;
   midy = getmaxy() / 2;
  /* move the C.P. to the center of the screen */
   moveto(midx, midy);
  /* output text starting at the C.P. */
   outtext("This ");
   outtext("is ");
   outtext("a ");
   outtext("test.");
  /* clean up */
   getch();
   closegraph();
   return 0;
函数名: outtextxy
功   能: 在指定位置显示一字符串
用   法: void far outtextxy(int x, int y, char *textstring);
程序例:
#include <stdlib.h>
#include <stdio.h>
#include <conio.h>
int main(void)
   int midx, midy;
   initgraph( ;gdriver, ;gmode, "");
       getch();
  /* output text at the center of the screen*/
   /* Note: the C.P. doesn't get changed.*/
   outtextxy(midx, midy, "This is a test.");
  /* clean up */
   getch();
   closegraph();
   return 0;
P类字母
函数名: parsfnm
功   能: 分析文件名
用   法: char *parsfnm (char *cmdline, struct fcb *fcbptr, int option);
程序例:
#include <process.h>
#include <string.h>
#include <stdio.h>
#include <dos.h>
int main(void)
   char line[80];
   struct fcb blk;
  /* get file name */
   printf("Enter drive and file name (no path - ie. a:file.dat)\n");
   gets(line);
  /* put file name in fcb */
   if (parsfnm(line, ;blk, 1) == NULL)
       printf("Error in parsfm call\n");
   else
       printf("Drive #%d   Name: %11s\n", blk.fcb_drive, blk.fcb_name);
  return 0;
函数名: peek
功   能: 检查存储单元
用   法: int peek(int segment, unsigned offset);
程序例:
#include <stdio.h>
#include <conio.h>
#include <dos.h>
int main(void)
   int value = 0;
  printf("The current status of your keyboard is:\n");
   value = peek(0x0040, 0x0017);
   if (value ; 1)
       printf("Right shift on\n");
   else
       printf("Right shift off\n");
  if (value ; 2)
       printf("Left shift on\n");
   else
       printf("Left shift off\n");
  if (value ; 4)
       printf("Control key on\n");
   else
       printf("Control key off\n");
  if (value ; 8)
       printf("Alt key on\n");
   else
       printf("Alt key off\n");
  if (value ; 16)
       printf("Scroll lock on\n");
   else
       printf("Scroll lock off\n");
  if (value ; 32)
       printf("Num lock on\n");
   else
       printf("Num lock off\n");
  if (value ; 64)
       printf("Caps lock on\n");
   else
       printf("Caps lock off\n");
  return 0;
函数名: peekb
功   能: 检查存储单元
用   法: char peekb (int segment, unsigned offset);
程序例:
#include <stdio.h>
#include <conio.h>
#include <dos.h>
int main(void)
   int value = 0;
   value = peekb(0x0040, 0x0017);
   if (value ; 1)
   else
  if (value ; 2)
   else
  if (value ; 4)
   else
  if (value ; 8)
   else
  if (value ; 16)
   else
  if (value ; 32)
   else
  if (value ; 64)
   else
  return 0;
函数名: perror
功   能: 系统错误信息
用   法: void perror(char *string);
程序例:
#include <stdio.h>
int main(void)
   FILE *fp;
  fp = fopen("perror.dat", "r");
   if (!fp)
       perror("Unable to open file for reading");
   return 0;
函数名: pieslice
功   能: 绘制并填充一个扇形
用   法: void far pieslice(int x, int stanle, int endangle, int radius);
程序例:
#include <stdlib.h>
#include <stdio.h>
#include <conio.h>
int main(void)
   int midx, midy;
   int stangle = 45, endangle = 135, radius = 100;
       getch();
  /* set fill style and draw a pie slice */
   setfillstyle(EMPTY_FILL, getmaxcolor());
   pieslice(midx, midy, stangle, endangle, radius);
  /* clean up */
   getch();
   closegraph();
   return 0;
函数名: poke
功   能: 存值到一个给定存储单元
用   法: void poke(int segment, int offset, int value);
程序例:
#include <dos.h>
#include <conio.h>
int main(void)
   clrscr();
   cprintf("Make sure the scroll lock key is off and press any key\r\n");
   getch();
   poke(0x0000,0x0417,16);
   cprintf("The scroll lock is now on\r\n");
   return 0;
函数名: pokeb
功   能: 存值到一个给定存储单元
用   法: void pokeb(int segment, int offset, char value);
程序例:
#include <dos.h>
#include <conio.h>
int main(void)
   clrscr();
   getch();
   pokeb(0x0000,0x0417,16);
   return 0;
函数名: poly
功   能: 根据参数产生一个多项式
用   法: double poly(double x, int n, double c[]);
程序例:
#include <stdio.h>
#include <math.h>
/* polynomial:   x**3 - 2x**2 + 5x - 1 */
int main(void)
   double array[] = { -1.0, 5.0, -2.0, 1.0 };
   double result;
  result = poly(2.0, 3, array);
   printf("The polynomial: x**3 - 2.0x**2 + 5x - 1 at 2.0 is %lf\n",
           result);
   return 0;
函数名: pow
功   能: 指数函数(x的y次方)
用   法: double pow(double x, double y);
程序例:
#include <math.h>
#include <stdio.h>
int main(void)
   double x = 2.0, y = 3.0;
  printf("%lf raised to %lf is %lf\n", x, y, pow(x, y));
   return 0;
函数名: pow10
功   能: 指数函数(10的p次方)
用   法: double pow10(int p);
程序例:
#include <math.h>
#include <stdio.h>
int main(void)
   double p = 3.0;
  printf("Ten raised to %lf is %lf\n", p, pow10(p));
   return 0;
函数名: printf
功   能: 产生格式化输出的函数
用   法: int printf(char *format...);
程序例:
#include <stdio.h>
#include <string.h>
#define I 555
#define R 5.5
int main(void)
   int i,j,k,l;
   char buf[7];
   char *prefix = buf;
   char tp[20];
   printf("prefix   6d       6o       8x         10.2e         "
           "10.2f\n");
   strcpy(prefix,"%");
   for (i = 0; i < 2; i++)
       for (j = 0; j < 2; j++)
         for (k = 0; k < 2; k++)
     for (l = 0; l < 2; l++)
               if (i==0)   strcat(prefix,"-");
               if (j==0)   strcat(prefix,"+");
               if (k==0)   strcat(prefix,"#");
               if (l==0)   strcat(prefix,"0");
               printf("%5s |",prefix);
               strcpy(tp,prefix);
               strcat(tp,"6d |");
               printf(tp,I);
               strcpy(tp,"");
               strcpy(tp,prefix);
               strcat(tp,"6o |");
               printf(tp,I);
               strcpy(tp,"");
               strcpy(tp,prefix);
               strcat(tp,"8x |");
               printf(tp,I);
               strcpy(tp,"");
               strcpy(tp,prefix);
         strcat(tp,"10.2e |");
         printf(tp,R);
         strcpy(tp,prefix);
         strcat(tp,"10.2f |");
         printf(tp,R);
         printf("   \n");
         strcpy(prefix,"%");
   return 0;
函数名: putc
功   能: 输出一字符到指定流中
用   法: int putc(int ch, FILE *stream);
程序例:
#include <stdio.h>
int main(void)
   char msg[] = "Hello world\n";
   int i = 0;
  while (msg)
       putc(msg[i++], stdout);
   return 0;
函数名: putch
功   能: 输出字符到控制台
用   法: int putch(int ch);
程序例:
#include <stdio.h>
#include <conio.h>
int main(void)
   char ch = 0;
  printf("Input a string:");
   while ((ch != '\r'))
       ch = getch();
       putch(ch);
   return 0;
函数名: putchar
功   能: 在stdout上输出字符
用   法: int putchar(int ch);
程序例:
#include <stdio.h>
/* define some box-drawing characters */
#define LEFT_TOP   0xDA
#define RIGHT_TOP 0xBF
#define HORIZ     0xC4
#define VERT       0xB3
#define LEFT_BOT   0xC0
#define RIGHT_BOT 0xD9
int main(void)
   char i, j;
  /* draw the top of the box */
   putchar(LEFT_TOP);
   for (i=0; i<10; i++)
       putchar(HORIZ);
   putchar(RIGHT_TOP);
   putchar('\n');
  /* draw the middle */
   for (i=0; i<4; i++)
       putchar(VERT);
       for (j=0; j<10; j++)
         putchar(' ');
       putchar(VERT);
       putchar('\n');
  /* draw the bottom */
   putchar(LEFT_BOT);
       putchar(HORIZ);
   putchar(RIGHT_BOT);
   putchar('\n');
  return 0;
函数名: putenv
功   能: 把字符串加到当前环境中
用   法: int putenv(char *envvar);
程序例:
#include <stdio.h>
#include <stdlib.h>
#include <alloc.h>
#include <string.h>
#include <dos.h>
int main(void)
   char *path, *ptr;
   int i = 0;
  /* get the current path environment */
   ptr = getenv("PATH");
  /* set up new path */
   path = malloc(strlen(ptr)+15);
   strcpy(path,"PATH=");
   strcat(path,ptr);
   strcat(path,";c:\\temp");
  /* replace the current path and display current environment */
   putenv(path);
   while (environ)
       printf("%s\n",environ[i++]);
  return 0;
函数名: putimage
功   能: 在屏幕上输出一个位图
用   法: void far putimage(int x, int y, void far *bitmap, int op);
程序例:
#include <stdlib.h>
#include <stdio.h>
#include <conio.h>
#define ARROW_SIZE 10
void draw_arrow(int x, int y);
int main(void)
   /* request autodetection */
   void *arrow;
   int x, y, maxx;
   unsigned int size;
       getch();
  maxx = getmaxx();
   x = 0;
   y = getmaxy() / 2;
  /* draw the image to be grabbed */
   draw_arrow(x, y);
  /* calculate the size of the image */
   size = imagesize(x, y-ARROW_SIZE, x+(4*ARROW_SIZE), y+ARROW_SIZE);
  /* allocate memory to hold the image */
   arrow = malloc(size);
  /* grab the image */
   getimage(x, y-ARROW_SIZE, x+(4*ARROW_SIZE), y+ARROW_SIZE, arrow);
  /* repeat until a key is pressed */
   while (!kbhit())
       /* erase old image */
       putimage(x, y-ARROW_SIZE, arrow, XOR_PUT);
      x += ARROW_SIZE;
       if (x >= maxx)
           x = 0;
      /* plot new image */
  /* clean up */
   free(arrow);
   closegraph();
   return 0;
   /* draw an arrow on the screen */
   moveto(x, y);
   linerel(4*ARROW_SIZE, 0);
   linerel(-2*ARROW_SIZE, -1*ARROW_SIZE);
   linerel(0, 2*ARROW_SIZE);
   linerel(2*ARROW_SIZE, -1*ARROW_SIZE);
函数名: putpixel
功   能: 在指定位置画一像素
用   法: void far putpixel (int x, int y, int pixelcolor);
程序例:
#include <stdlib.h>
#include <stdio.h>
#include <conio.h>
#include <dos.h>
#define PIXEL_COUNT 1000
#define DELAY_TIME   100   /* in milliseconds */
int main(void)
   int i, x, y, color, maxx, maxy, maxcolor, seed;
       getch();
  maxx = getmaxx() + 1;
   maxy = getmaxy() + 1;
   maxcolor = getmaxcolor() + 1;
  while (!kbhit())
       /* seed the random number generator */
       seed = random(32767);
       srand(seed);
       for (i=0; i<PIXEL_COUNT; i++)
   x = random(maxx);
         y = random(maxy);
         color = random(maxcolor);
         putpixel(x, y, color);
      delay(DELAY_TIME);
       srand(seed);
   x = random(maxx);
   y = random(maxy);
   if (color == getpixel(x, y))
     putpixel(x, y, 0);
  /* clean up */
   getch();
   closegraph();
   return 0;
2013yu
  • 注册日期2013-11-18
  • 发帖数10
  • QQ1911788843
  • 火币11枚
发布于:2013-11-18 22:02
2013yu
  • 注册日期2013-11-18
  • 发帖数10
  • QQ1911788843
  • 火币11枚
发布于:2013-11-18 22:03
喜欢啊啊啊
ji_r_h
骑士
骑士
  • 注册日期2013-07-24
  • 发帖数92
  • QQ182532534
  • 火币134枚
发布于:2013-11-30 16:07
