阅读:4827回复:0
[汇编源码]汇编GET TIME OF DAY(获取时间)源代码
发布于:2011-11-02 03:32
 | |  |  | INTRODUCTION
The first example is of a program that uses the system time of day. This example uses a conditional assembly to decide between two ways to get the time of day. One way is to use the DOS time of day function; the other way, illustrated by the second code example, uses the Bios time of day function. The second example can be used to replace the standard DOS call to get the time of day. This second example will return the time of day much faster than the standard DOS call.
FIRST EXAMPLE
This example runs until a set time of day occurs and then terminates. This code gets the time of day information from the DOS command line input data. If there is bad input data, then an error message is displayed, informing the user what the correct input data format is. While the program is waiting for the terminate time, it will scan the keyboard for an escape key to terminate the program on user demand.
; Wait for Time;This program can be executed inside of a .BAT file to; stall execution of the .BAT file until a set time of day;?????????????????????????????????????????????????????????? ???;conditional assembly flag, 0 to use DOS, 1 to use BIOS example.MODEL tinyuse_bios_flag EQU 1;----------- stack area ---------------.STACK 500;--------------------------------------.CODE;************* @@@@@@@@@@@@@@ ***************start proc near mov bx,80H ;index command line data mov al,[bx] ;get size of string variable mov ax,cs mov ds,ax ;reset data segment mov psp_seg,es ;save PSP address mov es,ax ;reset extra segment cmp al,4 ;is there data in string jb exit_bad ;branch if no data inc bx inc bx ;point to start of data ;get number out of buffer area call get_number jc exit_bad ;branch if number bad mov wait_hour,al ;save number in hour cmp al,23 ;?? number too large ?? ja exit_bad ;branch is too large ;check the number terminating character cmp ah,":" jne exit_bad ;branch if not : ;point to start of next number inc bx ;get next number out of buffer area call get_number jc exit_bad ;branch if number bad cmp al,59 ;?? number too large ?? ja exit_bad ;branch if too large mov wait_minute,al ;save number to minute ;display executing wait message mov ah,9 ;set DOS function number lea dx,wait_message int 21H ;DOS call to display message;________________________________;********** !!!!!!!! **********wait_loop: ;scan keyboard for keys mov ah,1 int 16H jz wait_no_key ;branch if no key mov ah,0 ;if here then keyboard data int 16H ;get key code from buffer cmp ax,3B00H ;check key code je exit ;branch if exit key cmp al,1BH ;check for ESC key je exit ;branch if ESC keywait_no_key: ;find out what time it is;conditional assembly ???????????????????? ;use this code if linking to code in this sectionIF use_bios_flag call get_time_of_day ;else use this code if calling DOS for timeELSE mov ah,2CH int 21H ;get current time of dayENDIF cmp ch,wait_hour jne wait_loop ;loop if not time cmp cl,wait_minute jne wait_loop ;loop if not time;^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^exit: mov ah,4CH int 21h ;terminate program;!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!exit_bad: mov ah,9 lea dx,exit_bad_message int 21H ;DOS call to display message jmp exit; ***** ^^^^^^^^ ***** ^^^^^^^^ ****get_number: ;on entry BX indexes ASCII number data in PSP segment area ;on exit if carry clear, ; register AL has binary number, from 0 to 99 ; BX indexes past the number, ; AH has exiting character code indexed by BX push ds mov ds,psp_seg mov al,[bx] inc bx call number_check jc get_number_bad mov ah,al mov al,[bx] call number_check jc get_number_1get_number_2a: cmp ah,0 je get_number_2 add al,10 dec ah jmp get_number_2aget_number_2: inc bx mov ah,al mov al,[bx]get_number_1: cmp al,":" je get_number_1a cmp al,0DH jne get_number_badget_number_1a: xchg al,ah pop ds clc ;set good number flag retget_number_bad: pop ds stc ;set bad number flag ret;#################################################number_check: ;this code checks for ASCII number in AL ; if it finds a number, then it makes it binary ; and returns with carry clear, else carry set cmp al,"0" jb number_bad cmp al,"9" ja number_bad and al,0FH clc ret stc ret;*************************start endp;+++ this routine combines data and code into one segment +++; define data areapsp_seg dw 0wait_hour db 0wait_minute db 0wait_message db 0DH,0AH,0DH,0AH db "Wait in progress, Press [ESC] to exit",0DH,0AH db "$"exit_bad_message db 0DH,0AH db "To use TimeWait program enter timeout data " db "from command line as example:",0DH,0AH,0DH,0AH db "TimeWait 11:30",0DH,0AH,0DH,0AH db "Note, timeout hours vary from 0 to 23, " db "and minutes from 0 to 59.",0DH,0AH db "$";______________________________________ end start
