阅读:2300回复:0
linux下巧用ps得到运行线程个数和线程启动时间
更多 发布于:2011-11-13 12:57
Linux进程运行了很久,怎么能够得到某一进程所有的线程个数并且得到它们的启动时间,除了读取/proc信息之外,我们可以使用ps简单的达到目的。
ps max  -o lstart,lwp,pid,nlwp,cmd
lstart     STARTED  time the command started.
nlwp       NLWP     number of lwps (threads) in the process. (alias thcount).
lwp        LWP      lwp (light weight process, or thread) ID of the lwp being reported.
                   (alias spid, tid).
BONO11-0-0-1:/root-# ps max  -o %mem,lstart,lwp,pid,nlwp,cmd
%MEM                  STARTED   LWP   PID NLWP CMD
0.0 Fri Nov 11 13:25:29 2011     -     1    1 init [3]
  - Fri Nov 11 13:25:29 2011     1     -    - -
0.0 Fri Nov 11 13:25:29 2011     -     2    1 [migration/0]
  - Fri Nov 11 13:25:29 2011     2     -    - -
0.0 Fri Nov 11 13:25:29 2011     -     3    1 [ksoftirqd/0]
  - Fri Nov 11 13:25:29 2011     3     -    - -
0.0 Fri Nov 11 13:50:46 2011     - 31012   8 /opt/proxy/bin/http_stack Http Stack benchHttp__asr_1_h   - Fri Nov 11 13:50:46 2011 31012     -    - -
  - Fri Nov 11 13:50:46 2011 31016     -    - -
  - Fri Nov 11 13:50:46 2011 31018     -    - -
  - Fri Nov 11 13:50:46 2011 31019     -    - -
  - Fri Nov 11 13:50:47 2011 31855     -    - -
  - Fri Nov 11 13:50:47 2011 31856     -    - -
  - Fri Nov 11 13:50:47 2011 31857     -    - -
  - Fri Nov 11 13:50:47 2011 31926     -    - -
0.0 Fri Nov 11 17:14:19 2011     - 31272    1 sshd: root@notty
  - Fri Nov 11 17:14:19 2011 31272     -    - -
我们可以验证正好有8个task.
BONO11-0-0-1:/root-# ls /proc/31012/task/
31012  31016  31018  31019  31855  31856  31857  31926
