阅读:4659回复:0
[汇编源码]抓取屏幕内容(字符模式)
更多 发布于:2011-11-20 07:38
输入格式:
  先输入抓取屏幕的左上角行列号,再输入抓取屏幕的右下角行列号.输入第3行要输入03
  0=<行号<=24,0=<列号<=79
DATA SEGMENT
num db ?,?,?,?
nm1 db ?
nm2 db ?
message1 db 'row1:','$'
buf1 db 3,?
data1 db ?
data2 db ?
message2 db ' col1:','$'
buf2 db 3,?
data3 db ?
data4 db ?
message3 db ' row2:','$'
buf3 db 3,?
data5 db ?
data6 db ?
message4 db ' col2:','$'
buf4 db 3,?
data7 db ?
data8 db ?
shuju db 2000 dup(?)
DATA ENDS
CODE SEGMENT
  ASSUME  CS:CODE,DS:DATA
START:
  MOV AX,DATA
  MOV DS,AX
  lea dx,message1
  mov ah,9
  int 21h
  MOV DX,OFFSET buf1
  MOV AH,0AH
  INT 21H
  mov cx,0
  mov al,data1
  sub al,30h
  mov bl,10
  mul bl
  add cx,ax
  mov al,data2
  sub al,30h
  add cx,ax
  mov num,cl
 mov dl,13
  mov ah,2
  int 21h
  mov dl,10
  mov ah,2
  int 21h
 lea dx,message2
  mov ah,9
  int 21h
  MOV DX,OFFSET buf2
  MOV AH,0AH
  INT 21H
  mov cx,0
  mov al,data3
  sub al,30h
  mul bl
  add cx,ax
  mov al,data4
  sub al,30h
  add cx,ax
  mov num+1,cl
 mov dl,13
  mov ah,2
  int 21h
  mov dl,10
  mov ah,2
  int 21h
 lea dx,message3
  mov ah,9
  int 21h
  MOV DX,OFFSET buf3
  MOV AH,0AH
  INT 21H
  mov cx,0
  mov al,data5
  sub al,30h
  mul bl
  add cx,ax
  mov al,data6
  sub al,30h
  add cx,ax
  mov num+2,cl
 mov dl,13
  mov ah,2
  int 21h
  mov dl,10
  mov ah,2
  int 21h
 lea dx,message4
  mov ah,9
  int 21h
  MOV DX,OFFSET buf4
  MOV AH,0AH
  INT 21H
  mov cx,0
  mov al,data7
  sub al,30h
  mul bl
  add cx,ax
  mov al,data8
  sub al,30h
  add cx,ax
  mov num+3,cl
 mov al,num
  cmp al,0
  js exit1
  cmp al,25
  jns exit1
 mov al,num+2
  cmp al,0
  js exit1
  cmp al,25
  jns exit1
 mov al,num+1
  cmp al,0
  js exit1
  cmp al,80
  jns exit1
 mov al,num+3
  cmp al,0
  js exit1
  cmp al,80
  jns exit1
 mov al,num
  mov ah,num+2
  cmp ah,al
  js exit1
  mov al,num+1
  mov ah,num+3
  cmp ah,al
  js exit1
 mov al,num
  mov ah,num+2
  sub ah,al
  add ah,1
  mov nm1,ah
  mov al,num+1
  mov ah,num+3
  sub ah,al
  add ah,1
  mov nm2,ah
 mov ax,0b800h
  mov es,ax
  mov al,num
  mov bl,80
  mul bl
  mov bh,0
  mov bl,num+1
  add ax,bx
  mov bl,2
  mul bx
  mov bx,ax
  jmp flag1
exit1:
  jmp exit
flag1:
  lea si,shuju
  mov ch,0
  mov cl,nm1
again1:
  push cx
  mov cl,nm2
  push bx
  push si
again2:
  mov ah,byte ptr es:[bx]
  mov [si],ah
  add bx,2
  add si,1
loop again2
  pop si
  add si,80
  pop bx
  add bx,160
  pop cx
loop again1
lea si,shuju
  mov ch,0
  mov cl,nm1
again3:
  mov dl,13
  mov ah,2
  int 21h
  mov dl,10
  mov ah,2
  int 21h
  push cx
  mov cl,nm2
  mov bx,0
  push si
again4:
  mov dl,[si]
  mov ah,2
  int 21h
  add si,1
loop again4
   pop si
  add si,80
  pop cx
loop again3
exit:
  MOV AH,4CH
  INT 21H
CODE ENDS
END START
