阅读:4525回复:0
一个计时器的实现C/C++
更多 发布于:2011-11-20 10:15
直接上代码
定义头文件:
//: C09:Cpptime.h
// From Thinking in C++, 2nd Edition
// Available at http://www.BruceEckel.com
// (c) Bruce Eckel 2000
// Copyright notice in Copyright.txt
// A simple time class
#ifndef CPPTIME_H
#define CPPTIME_H
#include <ctime>
#include <cstring>
class Time {
   time_t t;
   tm local;
   char asciiRep[26];
   unsigned char lflag, aflag;
   void updateLocal() {
       if(!lflag) {
           local = *localtime(;t);
           lflag++;
   void updateAscii() {
       if(!aflag) {
           updateLocal();
           strcpy(asciiRep,asctime(;local));
           aflag++;
public:
   Time() { mark(); }
   void mark() {
       lflag = aflag = 0;
       time(;t);
   const char* ascii() {
       updateAscii();
       return asciiRep;
   // Difference in seconds:
   int delta(Time* dt) const {
       return int(difftime(t, dt->t));
   int daylightSavings() {
       updateLocal();
       return local.tm_isdst;
   int dayOfYear() { // Since January 1
       updateLocal();
       return local.tm_yday;
   int dayOfWeek() { // Since Sunday
       updateLocal();
       return local.tm_wday;
   int since1900() { // Years since 1900
       updateLocal();
       return local.tm_year;
   int month() { // Since January
       updateLocal();
       return local.tm_mon;
   int dayOfMonth() {
       updateLocal();
       return local.tm_mday;
   int hour() { // Since midnight, 24-hour clock
       updateLocal();
       return local.tm_hour;
   int minute() {
       updateLocal();
       return local.tm_min;
   int second() {
       updateLocal();
       return local.tm_sec;
#endif // CPPTIME_H ///:~
使用示例:
//: C09:Cpptime.cpp
// Testing a simple time class
#include "head.h"
#include <iostream>
using namespace std;
int main() {
   Time start;
   for(int i = 1; i < 1000; i++) {
       cout << i << ' ';
       if(i%10 == 0) cout << endl;
   Time end;
   cout << endl;
   cout << "start = " << start.ascii();
   cout << "end = " << end.ascii();
   cout << "delta = " << end.delta(;start);
