阅读:2975回复:0
在linux下查看文件夹和文件大小
更多 发布于:2011-12-07 17:08
1.df命令可以显示目前所有文件系统的可用空间及使用情形
[1].Command:df -h
Filesystem Size  Used Avail Use% Mounted on
/dev/mapper/VolGroup00-LogVol00 20G  4.1G  15G 23% /
/dev/mapper/VolGroup00-LogVol03 3.9G 638M  3.1G 17% /var
/dev/mapper/VolGroup00-LogVol02 2.0G 68M  1.8G 4% /tmp
/dev/cciss/c0d0p1 99M   22M   73M  23% /boot
/dev/mapper/VolGroup00-data 242G  124g  116G  52% /data0
tmpfs 4.0G  0  4.0G  0% /dev/shm
immdb2:9421 3.0T  503G  2.5T  17% /mnt/mfs
参数-h 表示使用「Human-readable」的输出,也就是在档案系统大小使用GB、MB 等易读的格式。
2.查询文件或文件夹的磁盘使用空间
[1].Command:du -h
该命令用户统计文件大小相加,在当前目录下各子目录文件相加的结果,形如
1.9G ./communication
180K ./file/2011-12-06
244K ./file
36K ./meeting/2011-12-06
44K ./meeting
1.2G ./action/2011-12-06
1.2G ./action
11G . . www.atcpu.com
[2].Command:du -h [-path],获取指定目录下各子子目录文件相加的结果,形如
du -h ~
1.2G /u/imm/push/logs/2011-12-05
2.2G /u/imm/push/logs/2011-11-24
2.1G /u/imm/push/logs/2011-11-19
257M/u/imm/push/logs/2011-10-15
1.8G/u/imm/push/logs/2011-11-16
1.4G/u/imm/push/logs/2011-11-07
102G/u/imm
[3].Command:du -h [-path/*],获取某指定目录下各个文件的大小,形如
du -h 2011-12-06/*.log
3.3M2011-12-06/job.2011-12-06-00-0.log
3.2M2011-12-06/job.2011-12-06-01-0.log
3.2M2011-12-06/job.2011-12-06-02-0.log
3.2M2011-12-06/job.2011-12-06-03-0.log
3.2M 2011-12-06/job.2011-12-06-04-0.log
3.2M 2011-12-06/job.2011-12-06-05-0.log
3.3M 2011-12-06/job.2011-12-06-06-0.log
3.3M 2011-12-06/job.2011-12-06-07-0.log
3.3M 2011-12-06/job.2011-12-06-08-0.log
摘自 在路上
