阅读:1772回复:0
linux安装jdk脚本 方法
更多 发布于:2011-12-13 20:28
每次安装linux操作系统都需要下载jdk,安装jdk,设置环境变量,很麻烦,这次写个脚本,一次搞定
view plain
#!/bin/bash
chmod u+x jdk-6u29-linux-i586.bin
installPath=/usr/java
if [ ! -d /usr/java ];
then
   mkdir /usr/java
fi
./jdk-6u29-linux-i586.bin -D  /usr/java
cp  -R jdk1.6.0_29/ /usr/java/jdk1.6.0_29/
touch environment  www.atcpu.com
echo "PATH="$PATH:/usr/java/jdk1.6.0_29/bin"" >> environment
echo "JAVA_HOME=/usr/java/jdk1.6.0_29/bin" >> environment
echo "CLASSPATH=.:%JAVA_HOME%/lib/dt.jar:%JAVA_HOME%/lib/tools.jar" >> environment
rm -rf /etc/environment
cp environment /etc
source /etc/environment
update-alternatives --install /usr/bin/java java /usr/java/jdk1.6.0_29/bin/java 300
update-alternatives --install /usr/bin/javac javac /usr/java/jdk1.6.0_29/bin/javac 300
update-alternatives --config java
