阅读:3329回复:0
Window画图程序中画曲线的简单实现
更多 发布于:2011-12-14 00:12
下面是很入以前的一个程序,模仿Windows的画图程序中画曲线.其实原理简单得要命 ,就是一个PolyBezier函数.
那一位有兴趣的可以封装成一个类,方便以后用.
unit Unit1;
interface
uses
  Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
  Dialogs, StdCtrls;
type
  TStep=(sStartEnd,sCtrl1,sCtrl2);
  TForm1 = class(TForm)
    Button1: TButton;
    procedure FormCreate(Sender: TObject);
    procedure FormMouseDown(Sender: TObject; Button: TMouseButton;
      Shift: TShiftState; X, Y: Integer);
    procedure FormMouseMove(Sender: TObject; Shift: TShiftState; X,
      Y: Integer);
    procedure FormMouseUp(Sender: TObject; Button: TMouseButton;
    procedure FormPaint(Sender: TObject);
  private
    { Private declarations }
    isDown:Boolean;
    isOK:Boolean;  //标识一次Bezier线的绘制是否完成
    Step:TStep; //指示到那个阶段了
    StartP:TPoint;  //以下是四个点坐标
    EndP:TPoint;
    CtrP1:TPoint;
    CtrP2:TPoint;
  public
    { Public declarations }
  end;
var
  Form1: TForm1;
implementation
{$R *.dfm}
procedure TForm1.FormCreate(Sender: TObject);
begin
  self.DoubleBuffered:=true;
  isDown:=False;
  Step:=sStartEnd;
  isOK:=False;
end;
procedure TForm1.FormMouseDown(Sender: TObject; Button: TMouseButton;
begin
  isDown:=true;
  if Button=mbLeft then
  begin
    if (Step=sStartEnd) then
    begin
      StartP.X:=X;
      StartP.Y:=Y;
      EndP:=Point(X,Y);
      isOK:=False;
    end
    else if (Step=sCtrl1)  then
    begin
      CtrP1:=Point(X,Y);
      CtrP2:=Point(X,Y);
    end
    else if (Step=sCtrl2)  then
    begin
      CtrP2:=Point(X,Y);
    end;
  end;
end;
procedure TForm1.FormMouseMove(Sender: TObject; Shift: TShiftState; X,
  Y: Integer);
begin
  if isDown and (Shift=[ssLeft]) then
  begin
    begin
      EndP.X:=X;
      EndP.Y:=Y;
    end
    else if Step=sCtrl1 then
    begin
      CtrP1:=Point(X,Y);
      CtrP2:=Point(X,Y);
    end
    begin
      CtrP2:=Point(X,Y);
    end;
    self.Invalidate;
  end;
end;
procedure TForm1.FormMouseUp(Sender: TObject; Button: TMouseButton;
begin
  if isDown and (Button=mbLeft) then
  begin
    isDown:=False;
    if Step=sStartEnd then Step:=sCtrl1
    else if Step=sCtrl1 then Step:=sCtrl2
    else if Step=sCtrl2 then begin Step:=sStartEnd; isOK:=True; end;
  end;
end;
procedure TForm1.FormPaint(Sender: TObject);
begin
  if not isOK then
  begin
    begin
      self.Canvas.MoveTo(StartP.X,StartP.Y);
      self.Canvas.LineTo(EndP.X,EndP.Y);
    end
    else begin
     Self.Canvas.PolyBezier([StartP,CtrP1,CtrP2,EndP]);
    end;
  end else begin
  end;
end;
end.
