阅读:2762回复:0
用delphi批量导入某子目录下所有JPG图片文件到数据库
更多 发布于:2011-12-14 00:13
//保存图片到数据库
function imagesavetosql(dataset:TQuery;filename:String):boolean;
var
  imagejpg:TJPEGImage; //jpg图片
  MyStm:TMemoryStream;
begin
  result:=false;
  MyStm:=TMemoryStream.Create;
  imagejpg:=Tjpegimage.Create;
  if filename<>'' then
  begin
    imagejpg.LoadFromFile(filename);
    imagejpg.SaveToStream(MyStm);
    MyStm.Position:=0;
    TBlobField(dataset.FieldByName('pict')).LoadFromStream(MyStm); //不可与DMImage之类控件,因为其只支持BMP
    result:=true;
  end;
  MyStm.Free;
  imagejpg.free;
end;
//界面上添加TDirectoryListBox,TGauge控件
procedure Tfrmpict.BitBtn2Click(Sender: TObject);
var
  dirlist:TStringList;
  i:Integer;
begin
  inherited;
  if chk_road.Checked  then
  begin
    dirlist:=TStringList.Create ;
    dirlist.Clear;
    try
      GetAllFileName(DirectoryListBox1.Directory,dirlist);
      if dirlist.Count>0 then
      begin
      Gauge1.MinValue :=0;
      Gauge1.MaxValue:= dirlist.Count-1;
      for i:=0 to dirlist.Count-1 do
      begin
       with dm.qry_pict do
       begin
         Insert;
         Fields[0].AsString:=copy(dirlist.Strings,1,pos('.',dirlist.Strings)-1);
         if imagesavetosql(dm.qry_pict,dirlist.Strings )=false then
         begin
         ShowMessage('导入'+dirlist.Strings+'.jpg图片时出错');
         Abort;
         end;
         Post;
       end;  //with
       Gauge1.AddProgress(1);
      end;  //for
      end  //if
      else
      ShowMessage('该目录下不存在JPG类型图片');
    finally
      dirlist.Free;
    end;
  end
  else
     ShowMessage('请执行路径选取操作');
  //Close;
end;
