阅读:3317回复:0
asp中常用的文件处理函数
更多 发布于:2011-12-15 23:15
asp 中处理文件上传以及删除时常用的自定义函数
'所有自定义的VBS函数
function DeleteFile(Filename) '删除文件
if Filename<>"" then
  Set fso = server.CreateObject("Scripting.FileSystemObject")
  if fso.FileExists(Filename) then
   fso.DeleteFile Filename
  end if
  set fso = nothing
end if
end function
function CreateDIR(byval LocalPath) '建立目录的程序,如果有多级目录,则一级一级的创建
on error resume next
LocalPath = replace(LocalPath,"\","/")
set FileObject = server.createobject("Scripting.FileSystemObject")
patharr = split(LocalPath,"/")
path_level = ubound(patharr)
for i = 0 to path_level
  if i=0 then pathtmp=patharr(0) ; "/" else pathtmp = pathtmp ; patharr(i) ; "/"
  cpath = left(pathtmp,len(pathtmp)-1)
  if not FileObject.FolderExists(cpath) then FileObject.CreateFolder cpath
next
set FileObject = nothing
if err.number<>0 then
  CreateDIR = false
  err.Clear
else
  CreateDIR = true
end if
end function
function SaveRandFileName(byval szFilename) '根据原文件名生成新的随机文件名
randomize
'ranNum=int(90000*rnd)+10000
'if month(now)<10 then c_month="0" ; month(now) else c_month=month(now)
'if day(now)<10 then c_day="0" ; day(now) else c_day=day(now)
'if hour(now)<10 then c_hour="0" ; hour(now) else c_hour=hour(now)
'if minute(now)<10 then c_minute="0" ; minute(now) else c_minute=minute(now)
'if second(now)<10 then c_second="0" ; second(now) else c_second=minute(now)
fileExt_a=split(szFilename,".")
fileExt=lcase(fileExt_a(ubound(fileExt_a)))
SaveRandFileName=replace(replace(replace(now,":",""),"-","")," ","");int(10*rnd);".";fileExt
'GenerateRandomFileName = year(now);c_month;c_day;c_hour;c_minute;c_second;"_";ranNum;".";fileExt
end function
function jaron_replacer(strContent,start_string,end_string,replace_string)
'CMS替换函数:源字符串,前部分,后部分,替换成的字符
'返回被替换后的字符串
jaron_replacer = replace(strContent,mid(strContent,instr(strContent,start_string),instr(strContent,end_string)+len(end_string)-1),replace_string)
end function
function replaceplus(strContent,start_string,end_string,replace_string)
'文档中,将所有开始,结束之间的所有字符删除
MARKCOUNTS = ubound(split(strContent,start_string))
PRESTRING = strContent
for i=0 to MARKCOUNTS
STARTMARK=instr(1,PRESTRING,start_string,1)
if STARTMARK=0 then exit for
COMPMARK=instr(1,PRESTRING,end_string,1) + len(end_string)
VerString=mid(PRESTRING,STARTMARK,COMPMARK - STARTMARK)
PRESTRING = replace(PRESTRING,VerString,replace_string)
next
replaceplus = PRESTRING
if err.number<>0 then err.Clear
end function
