阅读:4322回复:0
成功粉碎一起来自四川的网络攻击的过程
更多 发布于:2011-12-18 19:30
攻击现象
时间:2011.12.09 14:25
刚才用SecureCRT登录到公司的Linux服务器之后,不久之后再用SecureCRT重新开一屏登录报错“Connection reset by peer”,从本地Linux上使用sftp下载文件也报错:
[root@node57 backup]# sftp xxx.xx.xxx.xx
Connecting to xxx.xx.xxx.xx...
ssh_exchange_identification: Connection closed by remote host
Couldn't read packet: Connection reset by peer
解决过程
幸好,已经登录的那个ssh会话还没有断开,并且能正常响应,先用w命令看一下:
[root@web ~]# w
14:29:12 up 494 days, 17:58,  2 users,  load average: 0.02, 0.44, 1.15
USER     TTY      FROM              LOGIN@   IDLE   Jcpu   PCPU WHAT
root     pts/2    cvsbank          14:08   19.00s  0.63s  0.63s -bash
root     pts/3    cvsbank          14:16    0.00s  0.33s  0.00s w
[root@web ~]#
看上去挺正常。再用netstat看一下:
[root@web ~]# netstat -anp | grep :22
tcp        0      0 0.0.0.0:22                  0.0.0.0:*                   LISTEN      2701/sshd
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3921        TIME_WAIT   -
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3927        TIME_WAIT   -
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3911        TIME_WAIT   -
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3917        TIME_WAIT   -
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3954        TIME_WAIT   -
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3953        TIME_WAIT   -
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3957        TIME_WAIT   -
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3941        TIME_WAIT   -
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3946        TIME_WAIT   -
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3950        TIME_WAIT   -
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3949        TIME_WAIT   -
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3986        TIME_WAIT   -
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3993        TIME_WAIT   -
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3970        TIME_WAIT   -
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3968        TIME_WAIT   -
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3974        TIME_WAIT   -
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3972        TIME_WAIT   -
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3973        TIME_WAIT   -
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:3977        TIME_WAIT   -
tcp        0     84 xxx.xx.xxx.xx:22            182.131.134.162:4020        ESTABLISHED 25876/sshd: root [p
tcp      808    704 xxx.xx.xxx.xx:22            182.131.134.162:4024        ESTABLISHED 25884/sshd: [accept
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:4003        ESTABLISHED 25824/sshd: root [p
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:4006        ESTABLISHED 25836/sshd: root [p
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:4004        ESTABLISHED 25828/sshd: root [p
tcp        0     84 xxx.xx.xxx.xx:22            182.131.134.162:4005        ESTABLISHED 25832/sshd: root [p
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:4010        ESTABLISHED 25846/sshd: root [p
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:4009        ESTABLISHED 25842/sshd: root [p
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:4014        ESTABLISHED 25862/sshd: root [p
tcp        0      0 xxx.xx.xxx.xx:22            182.131.134.162:4015        ESTABLISHED 25866/sshd: root [p
tcp        0    200 xxx.xx.xxx.xx:22            yy.yyy.yy.yy:47887          ESTABLISHED 19397/3
(其中,xxx.xx.xxx.xx是服务器ip地址,yy.yyy.yy.yy是我的机器的地址。)
哇,这么多相同的地址,看来是有人试图从182.131.134.162来进行ssh登录,
http://www.ip138.com/查下这个地址:
ip138.com IP查询(搜索IP地址的地理位置)
您查询的IP:182.131.134.162
本站主数据:四川省广安市 电信
参考数据一:四川省成都市 电信
我现在要做的是禁止此地址访问:
[root@web ~]# iptables -I INPUT -s 182.131.134.162 -j DROP
[root@web ~]#
再来看看有没有
[root@web ~]# netstat -anp | grep 182.131.134.162
tcp        0     84 xxx.xx.xxx.xx:22            182.131.134.162:4284        ESTABLISHED 26478/sshd: root [p
tcp        0     84 xxx.xx.xxx.xx:22            182.131.134.162:4285        ESTABLISHED 26482/sshd: root [p
tcp        0     84 xxx.xx.xxx.xx:22            182.131.134.162:4290        ESTABLISHED 26493/sshd: root [n
tcp        0     84 xxx.xx.xxx.xx:22            182.131.134.162:4291        ESTABLISHED 26498/sshd: root [n
tcp        0     84 xxx.xx.xxx.xx:22            182.131.134.162:4295        ESTABLISHED 26506/sshd: root [n
tcp        0     84 xxx.xx.xxx.xx:22            182.131.134.162:4293        ESTABLISHED 26502/sshd: root [n
tcp        0     84 xxx.xx.xxx.xx:22            182.131.134.162:4298        ESTABLISHED 26510/sshd: root [n
tcp        0     84 xxx.xx.xxx.xx:22            182.131.134.162:4299        ESTABLISHED 26514/sshd: root [n
tcp        0     84 xxx.xx.xxx.xx:22            182.131.134.162:4302        ESTABLISHED 26518/sshd: root [n
tcp        0     84 xxx.xx.xxx.xx:22            182.131.134.162:4303        ESTABLISHED 26522/sshd: root [n
杀掉这些列出的进程
[root@web ~]# kill 26478 26482 26493 26498 26506 26502 26510 26514 26518 26522
tcp        0     84 xxx.xx.xxx.xx:22            182.131.134.162:4284        ESTABLISHED 26481/sshd: root [n
tcp        0     84 xxx.xx.xxx.xx:22            182.131.134.162:4285        ESTABLISHED 26489/sshd: root [n
tcp        0     85 xxx.xx.xxx.xx:22            182.131.134.162:4290        FIN_WAIT1   -
tcp        0     85 xxx.xx.xxx.xx:22            182.131.134.162:4291        FIN_WAIT1   -
tcp        0     85 xxx.xx.xxx.xx:22            182.131.134.162:4295        FIN_WAIT1   -
tcp        0     85 xxx.xx.xxx.xx:22            182.131.134.162:4293        FIN_WAIT1   -
tcp        0     85 xxx.xx.xxx.xx:22            182.131.134.162:4298        FIN_WAIT1   -
tcp        0     85 xxx.xx.xxx.xx:22            182.131.134.162:4299        FIN_WAIT1   -
tcp        0     85 xxx.xx.xxx.xx:22            182.131.134.162:4302        FIN_WAIT1   -
tcp        0     85 xxx.xx.xxx.xx:22            182.131.134.162:4303        FIN_WAIT1   -
[root@web ~]# kill 26481 26489
tcp        0     85 xxx.xx.xxx.xx:22            182.131.134.162:4284        FIN_WAIT1   -
tcp        0     85 xxx.xx.xxx.xx:22            182.131.134.162:4285        FIN_WAIT1   -
[root@web ~]#
[root@web ~]#
[root@web ~]#
[root@web ~]#
过一会再看一下:
[root@web ~]#
终于搞定了。ssh登录和sftp下文件都正常了。
再次列出关键命令,用于禁止某个ip地址访问服务器:
