操作系统
linux技巧
linux安装memcached服务
linux安装memcached服务
发布于:2011-12-25 11:08
1.分别把memcached和libevent下载回来,放到/tmp 目录下:
# cd /tmp
# sudo wget
http://www.danga.com/memcached/dist/memcached-1.2.0.tar.gz
# sudo wget
http://www.monkey.org/~provos/libevent-1.2.tar.gz
2.先安装libevent:
# tar zxvf libevent-1.2.tar.gz
# cd libevent-1.2
# ./configure –prefix=/usr //如果出错需安装gcc,执行sudo apt-get install gcc
# make //如果出错需安装make,执行sudo apt-get install make
# sudo make install
3.测试libevent是否安装成功:
# ls -al /usr/lib | grep libevent
lrwxrwxrwx 1 root root 21 11?? 12 17:38 libevent-1.2.so.1 -> libevent-1.2.so.1.0.3
-rwxr-xr-x 1 root root 263546 11?? 12 17:38 libevent-1.2.so.1.0.3
-rw-r–r– 1 root root 454156 11?? 12 17:38 libevent.a
-rwxr-xr-x 1 root root 811 11?? 12 17:38 libevent.la
lrwxrwxrwx 1 root root 21 11?? 12 17:38 libevent.so -> libevent-1.2.so.1.0.3
表示都安装成功。
4.安装memcached,同时需要安装中指定libevent的安装位置:
# cd /tmp
# tar zxvf memcached-1.2.0.tar.gz
# cd memcached-1.2.0
# ./configure –with-libevent=/usr
# make
# sudo make install
5.测试是否成功安装memcached:
# ls -al /usr/local/bin/mem*
-rwxr-xr-x 1 root root 137986 11?? 12 17:39 /usr/local/bin/memcached
-rwxr-xr-x 1 root root 140179 11?? 12 17:39 /usr/local/bin/memcached-debug
6.启动Memcache的服务器端:
# /usr/local/bin/memcached -d -m 10 -u root -l 192.168.1.100 -p 12000 -c 256 -P /tmp/memcached.pid
-d选项是启动一个守护进程,
-m是分配给Memcache使用的
内存
数量,单位是MB,我这里是10MB,
-u是运行Memcache的用户,我这里是root,
-l是监听的服务器IP地址,如果有多个地址的话,我这里指定了服务器的IP地址192.168.0.200,
-p是设置Memcache监听的端口,我这里设置了12000,最好是1024以上的端口,
-c选项是最大运行的并发连接数,默认是1024,我这里设置了256,按照你服务器的负载量来设定,
-P是设置保存Memcache的pid文件,我这里是保存在/tmp/memcached.pid,
如果要结束Memcache进程,执行:
# kill `cat /tmp/memcached.pid`
7.测试Memcached:
[root@localhost /]# telnet 192.168.141.64 12000
Trying 192.168.141.64...
Connected to 192.168.141.64 (192.168.141.64).
Escape character is '^]'.
出现上面字符之后键入:
set key1 0 60 4
zhou
STORED
get key1
VALUE key1 0 4
zhou
END
至此Memcached安装成功!
8.想开机自动启动的话,只需在/etc/rc.d/rc.local中加入一行,下面命令
/usr/local/memcached/bin/memcached -d -m 10 -p 12000 -u apache -c 256
上面有些东西可以参考一下:即,ip不指定时,默认是本机,用户:最好选择是:apache 或deamon
这样,也就是属于哪个用户的服务,由哪个用户启动
