阅读:4080回复:0
[系统教程]Linux安全体系学习笔记之四:OpenSSL源代码分析(3)
发布于:2011-12-29 21:25
 | |  |  | BIO是对IO操作的封装,OpenSSL的BIO抽象接口不仅可以对SSL连接的I/O使用,也可以对非加密的网络连接和文件的I/O使用。BIO的相关源代码在crypto/bio文件夹下。 BIO的相关数据结构列出如下。 BIO结构: struct bio_st { BIO_METHOD *method; /* bio, mode, argp, argi, argl, ret */ long (*callback)(struct bio_st *,int,const char *,int, long,long); char *cb_arg; /* first argument for the callback */ int init; int shutdown; int flags; /* extra storage */ int retry_reason; int num; void *ptr; struct bio_st *next_bio; /* used by filter Bios */ struct bio_st *prev_bio; /* used by filter BIOs */ int references; unsigned long num_read; unsigned long num_write; CRYPTO_EX_DATA ex_data; }; BIO操作的结构: typedef struct bio_method_st { int type; const char *name; int (*bwrite)(BIO *, const char *, int); int (*bread)(BIO *, char *, int); int (*bputs)(BIO *, const char *); int (*bgets)(BIO *, char *, int); long (*ctrl)(BIO *, int, long, void *); int (*create)(BIO *); int (*destroy)(BIO *); long (*callback_ctrl)(BIO *, int, bio_info_cb *); } BIO_METHOD; BIO接口类型分为源/接收类型和过滤类型两种。 #define BIO_TYPE_DESCRIPTOR0x0100 /* socket, fd, connect or accept */ #define BIO_TYPE_FILTER 0x0200 #define BIO_TYPE_SOURCE_SINK 0x0400 1、源/接收类型 #define BIO_TYPE_MEM(1|0x0400) #define BIO_TYPE_FILE (2|0x0400) #define BIO_TYPE_FD (4|0x0400|0x0100) #define BIO_TYPE_SOCKET (5|0x0400|0x0100) #define BIO_TYPE_NULL (6|0x0400) #define BIO_TYPE_CONNECT(12|0x0400|0x0100)/* socket - connect */ #define BIO_TYPE_ACCEPT(13|0x0400|0x0100)/* socket for accept */ #define BIO_TYPE_BIO(19|0x0400)/* (half a) BIO pair */ #define BIO_TYPE_DGRAM(21|0x0400|0x0100) 2、过滤类型 #define BIO_TYPE_SSL(7|0x0200) #define BIO_TYPE_MD(8|0x0200) /* passive filter */ #define BIO_TYPE_BUFFER (9|0x0200)/* filter */ #define BIO_TYPE_CIPHER (10|0x0200)/* filter */ #define BIO_TYPE_BASE64 (11|0x0200)/* filter */ #define BIO_TYPE_PROXY_CLIENT (14|0x0200)/* client proxy BIO */ #define BIO_TYPE_PROXY_SERVER (15|0x0200)/* server proxy BIO */ #define BIO_TYPE_NBIO_TEST (16|0x0200)/* server proxy BIO */ #define BIO_TYPE_NULL_FILTER (17|0x0200) #define BIO_TYPE_BER (18|0x0200)/* BER -> bin filter */ #define BIO_TYPE_LINEBUFFER (20|0x0200)/* filter */ #define BIO_TYPE_ASN1 (22|0x0200)/* filter */ #define BIO_TYPE_COMP (23|0x0200)/* filter */ BIO过滤缓冲结构: typedef struct bio_f_buffer_ctx_struct { /* BIO *bio; */ /* this is now in the BIO struct */ int ibuf_size; /* how big is the input buffer */ int obuf_size; /* how big is the output buffer */ char *ibuf; /* the char array */ int ibuf_len; /* how many bytes are in it */ int ibuf_off; /* write/read offset */ char *obuf; /* the char array */ int obuf_len; /* how many bytes are in it */ int obuf_off; /* write/read offset */ } BIO_F_BUFFER_CTX;
