阅读:4009回复:0
ASP防XSS注入函数
更多 发布于:2012-01-18 13:21
'防XSS注入函数 更新于2009-04-21 by evio
 '与checkstr()相比, checkxss更加安全
 Function Checkxss(byVal ChkStr)
     Dim Str
     Str = ChkStr
     If IsNull(Str) Then
         CheckStr = ""
         Exit Function
     End If
     Str = Replace(Str, ";", ";")
     Str = Replace(Str, "'", "´")
     Str = Replace(Str, """", """)
         Str = Replace(Str, "<", "<")
         Str = Replace(Str, ">", ">")
         Str = Replace(Str, "/", "/")
         Str = Replace(Str, "*", "*")
     Dim re
     Set re = New RegExp
     re.IgnoreCase = True
     re.Global = True
     re.Pattern = "(w)(here)"
     Str = re.Replace(Str, "$1here")
     re.Pattern = "(s)(elect)"
     Str = re.Replace(Str, "$1elect")
     re.Pattern = "(i)(nsert)"
     Str = re.Replace(Str, "$1nsert")
     re.Pattern = "(c)(reate)"
     Str = re.Replace(Str, "$1reate")
     re.Pattern = "(d)(rop)"
     Str = re.Replace(Str, "$1rop")
     re.Pattern = "(a)(lter)"
     Str = re.Replace(Str, "$1lter")
     re.Pattern = "(d)(elete)"
     Str = re.Replace(Str, "$1elete")
     re.Pattern = "(u)(pdate)"
     Str = re.Replace(Str, "$1pdate")
     re.Pattern = "(s)(or)"
     Str = re.Replace(Str, "$1or")
         re.Pattern = "( )"
         re.Pattern = "(java)(script)"
     Str = re.Replace(Str, "$1script")
         re.Pattern = "(j)(script)"
         re.Pattern = "(vb)(script)"
         If Instr(Str, "expression") > 0 Then
                 Str = Replace(Str, "expression", "e&shy;xpression", 1, -1, 0) '防止xss注入
         End If
     Set re = Nothing
     Checkxss = Str
 End Function
 测试代码:
 <script> alert(/xss0/) </script>
 <img src= "javascript:alert(/xss1/) " width=100>
 <img src= "javascript:alert(/xss2/) " width=100>
 <img src= "javas cript:alert(/xss3/) " width=100>
 <img src= "# " onerror=alert(/xss4/)>
 <img src= "# "/**/onerror=alert(/xss5/) width=100>
 <img src= "# " style= "Xss:expression(alert(/xss6/)); ">
 <img src=";#x6a;#x61;#x76;#x61;#x73;#x63;#x72;#x69;#x70;#x74;#x3a;#x61;#x6c;#x65;#x72;#x74;#x28;#x27;#x58;#x53;#x53;#x27;#x29;#x3b">
 <SCRIPT LANGUAGE="JavaScript">
 eval("x6ax61x76x61x73x63x72x69x70x74x3ax61x6cx65x72x74x28x22x58x53x53x22x29")
 </SCRIPT>
