阅读:1160回复:0
IPTABLE减轻DDOS的设定
更多 发布于:2012-01-30 23:24
# Make sure NEW tcp connections are SYN packets
 iptables -N syn-flood
 iptables -A INPUT -p tcp --syn -j syn-flood
 iptables -A syn-flood -m limit --limit 1/s --limit-burst 4 -j RETURN
 iptables -A syn-flood -j DROP
 iptables -A INPUT -i eth0 -p tcp ! --syn -m state --state NEW -j DROP
 #SYN_RECV
 echo "1" > /proc/sys/net/ipv4/tcp_syncookies 0
 echo "10" > /proc/sys/net/ipv4/tcp_fin_timeout 60
 echo "1" > /proc/sys/net/ipv4/icmp_echo_ignore_all 0
 echo "1" > /proc/sys/net/ipv4/icmp_echo_ignore_broadcasts 0
 echo "5000" > /proc/sys/net/ipv4/tcp_max_syn_backlog 1024
 #TIME_WAIT
 echo "180000" > /proc/sys/net/ipv4/tcp_max_tw_buckets  180000
 echo "1" > /proc/sys/net/ipv4/tcp_rfc1337 0
 echo "1" > /proc/sys/net/ipv4/tcp_tw_recycle 0
 echo "1" > /proc/sys/net/ipv4/tcp_tw_reuse 0
 echo "5" > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_time_wait 120
 echo "10" > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_syn_recv 60
 echo "10" > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_syn_sent 120
 防止同步包洪水(Sync Flood)
 # iptables -A FORWARD -p tcp --syn -m limit --limit 1/s -j ACCEPT
 也有人写作
 #iptables -A INPUT -p tcp --syn -m limit --limit 1/s -j ACCEPT
 --limit 1/s 限制syn并发数每秒1次,可以根据自己的需要修改
 防止各种端口扫描
 # iptables -A FORWARD -p tcp --tcp-flags SYN,ACK,FIN,RST RST -m limit --limit 1/s -j ACCEPT
 Ping洪水攻击(Ping of Death)
 # iptables -A FORWARD -p icmp --icmp-type echo-request -m limit --limit 1/s -j ACCEPT
