阅读:6876回复:0
Flash AS动画实例:风吹云飘草动
更多 发布于:2012-01-31 23:37
  我们可以直接用Flash的ASAS代码生成风吹云飘,风吹着青草左右摇摆的动画。因为AS的运算会拖慢机器,所以这里就不提供效果演示了,给大家截个图。
  制作方法如下。
  首先建立两个空的影片剪辑cloud和grass。
  先建立云的影片剪辑(里面什么都不画)
  选择该元件的第一帧,添加如下代码。
//Number of clouds
clouds=6;
//These are just general boundaries.
//To use exact boundaries, create a mask in the parent level of the size desired
//Height of the sky
skyheight=Stage.height;
//Width of the sky
skywidth=Stage.width;
//Max size of a cloud
cloudsize=300;
//Amount of blur applied to the shapes to make them cloud-like
blursize=40;
//Clouds move at a random speed. this is the minimum speed
cloudminspeed=.5;
//Variance in speed from cloud to cloud
cloudspeedvariance=1;
//Create the clouds
for(c=1;c<=clouds;c++){
//create an empty movie clip to hold the cloud
 this.createEmptyMovieClip("cloud"+c,this.getNextHighestDepth());
//generate a cloud. Pass in the instance name of the newly created cloud
 shapecloud("cloud"+c);
//Set the x position to a random position within the boundaries
 eval("cloud"+c)._x=Math.random()*skywidth-eval("cloud"+c)._x/2;
//Set the y position to a random position within the boundaries
 eval("cloud"+c)._y=Math.random()*(skyheight)-eval("cloud"+c)._height;
//Run at the start of each frame
onEnterFrame=function(){
//Run for each cloud
//Move the cloud to the left according to its speed
  eval("cloud"+c)._x-=eval("cloud"+c).cloudspeed;
//If the cloud is past the stage to the left, reset it to the right. Create a new shape and color
  if(eval("cloud"+c)._x+(eval("cloud"+c)._width/2)+cloudsize<0){
//Reset the x position
   eval("cloud"+c)._x=skywidth;
//Reshape and recolor the cloud
//This function creates the shape and color of a cloud
function shapecloud(cloudid){
//Clear the current contents of the cloud
 eval(cloudid).clear();
//Set the new shade between 224 and 255. This number is used for the red, green, and blue, to create a grayscale color
 cloudcolor=Math.round(Math.random()*31)+224;
//Use no line
 eval(cloudid).lineStyle(undefined, (cloudcolor+cloudcolor*0x100+cloudcolor*0x10000), 100, false, "none", "none", "none", 1);
//Set the fill color. cloudcolor is used 3 times, for red, green, and blue
 eval(cloudid).beginFill((cloudcolor+cloudcolor*0x100+cloudcolor*0x10000));
//Set a starting coordinate for the cloud
 eval(cloudid).moveTo(Math.random()*cloudsize,Math.random()*cloudsize);
//Draw an invisible line to another point the combined lines form shapes, which are the clouds.
//They don't look much like clouds until the blur is applied
 eval(cloudid).lineTo(Math.random()*cloudsize,Math.random()*cloudsize);
//Apply a blur to the shape
 eval(cloudid).filters = [new flash.filters.BlurFilter(blursize,blursize,2)];
//Set a new cloud speed
 eval(cloudid).cloudspeed=Math.random()*cloudspeedvariance+cloudminspeed;
  同样办法再新建立一个草的影片剪辑
  选择第一帧添加如下代码。
//Height of each blade of grass
grassheight=35;
//Average space in between each blade of grass
grassspacing=5;
//Maximum sway of each blade of grass
maxsway=20;
//Number of blades of grass along the x axis
xplots=30;
//Number of blades of grass along the y axis
yplots=20;
//The wind has an x position and the grass is attracted to the position
windxpos=0;
//Velocity of the wind left and right
windspeed=0;
//Gives the grass a bent effect. The grass bends 1/4 of the way up
grasscontrol=grassheight/4;
//Array containing the info for each blade of grass
grasscoords=[];
//These loops go through the field, planting each blade of grass
for (xpos=0; xpos
  然后回到主场景中,建立两个图层,下面的为云的图层,上面的为草的图层,这里我绘制了一个放草的框框。
  按Ctrl+L打开库分别把草元件和云元件放到相应的图层。给草命名实例grass。
  最后可以测试影片了!但是好象机器运行速度在减慢啊!祝你好运!
喜欢1 评分0
coolmancoolma...
