阅读:3567回复:0
[二级考试]计算机二级VB常用算法:进制转化进八进制整数
更多 发布于:2012-08-22 13:54
补充代码
  本程序是把给定的二进制整数转换为八进制整数。
以下是片段:
  Private Sub Command1_Click()
  Dim a As String, b As String, c As String
  Dim L As Integer, m As Integer, n As Integer
  a = InputBox("请输入一个二进制数", "输入框")
  (1)
  a = String(L, "0") ; a
  (2)
  For m = 1 To n / 3
  b = Mid(a, 3 * m - 2, 3)
  (3)
  Next m
  Text1.Text = c
  End Sub
  Private Function zh(s As String) As String
  Dim i As Integer, n As Integer, p As Integer
  p = 1
  For i = 2 To 0 Step -1
  (4)
  p = p + 1
  Next i
  zh = Str(n)
  End Function
