阅读:3709回复:0
[二级考试]计算机二级VB常用算法:进制转化进制字符
更多 发布于:2012-08-22 13:54
(2-16)进制字符串转换为十进制正整数。
  思路:R进制数每位数字乘以权值之和即为十进制数。
  算法实现:
以下是片段:
  Private Function Tran(ByVal s As String, ByVal r As Integer) As integer
  Dim n As Integer, dec As Integer
  s = UCase(Trim(s))
  For i% = 1 To Len(s)
  If Mid(s, i, 1) >= "A" Then
  n = Asc(Mid(s, i, 1)) - Asc("A") + 10
  Else
  n = Val(Mid(s, i, 1))
  End If
  dec = dec + n * r ^ (Len(s) - i)
  Next i
  Tran = dec
  End Function
