阅读:3866回复:0
[思科考试]思科认证:思科路由实验项目全程记录及知识点归纳(4)
更多 发布于:2012-08-22 14:54
尝试4 在P2规模内实现IGRP的非等价负载平衡
等价负载平衡同RIP部门,设置膳缦慊什么非凡之处
[P2R4]
int f0/0
bandwidth 10000
no ip route-cache
int s1/0
bandwidth 1000
no ip route-cache
router igrp 100
vari 10
access-list 101 permit ip icmp any 100.100.100.0 0.0.0.255
debug ip pac 101
验证结不美观
使用sh int f0/0察看其默认BW为BW 100000 Kbit
使用sh int s1/0察看其默认BW为BW 1544 Kbit
可是奇异的是,我还没有设置variance,且BW分歧的情形下,基于Dynamips的metric计较值竟然不异,先不管它
I 100.0.0.0/8 [100/8986] via 172.19.1.1, 00:00:09, FastEthernet0/0
[100/8986] via 172.18.1.1, 00:00:18, Serial1/0
如不美观只是设置了带宽,则所有的pac将从f0/0发出
[pre][Copy to clipboard]
CODE:
P2R4#ping 100.100.100.100 re 2
Type escape sequence to abort.
Sending 2, 100-byte ICMP Echos to 100.100.100.100, timeout is 2 seconds:
Success rate is 100 percent (2/2), round-trip min/avg/max = 12/14/16 ms
P2R4#
00:54:07: IP: tableid=0, s=172.19.1.2 (local), d=100.100.100.100 (FastEthernet0/0), routed via RIB
00:54:07: IP: s=172.19.1.2 (local), d=100.100.100.100 (FastEthernet0/0), len 100, sending
16:31:16: RIP: received packet with MD5 authentication    [/pre]
认证成功
附加部门
在P1R2上采用同样密钥,可是在接口上应用的时辰如不美观采用明文体例 ip rip auth mod text(P1R1采用MD5加密)
因为双方不匹配,则一样会invalid authentication
设置好variance往后,sh ip route
I 100.0.0.0/8 [100/8986] via 172.19.1.1, 00:01:09, FastEthernet0/0
[100/12510] via 172.18.1.1, 00:00:16, Serial1/0
两条路出来了,然后不雅察看抓包即可
CODE:
P1R4#ping 100.100.100.100 re 2
P1R4#
00:58:24: IP: tableid=0, s=172.19.1.1 (local), d=100.100.100.100 (FastEthernet0/0), routed via RIB
00:58:24: IP: s=172.19.1.1 (local), d=100.100.100.100 (FastEthernet0/0), len 100, sending
00:58:24: IP: tableid=0, s=172.18.1.1 (local), d=100.100.100.100 (Serial1/0), routed via RIB
00:58:24: IP: s=172.18.1.1 (local), d=100.100.100.100 (Serial1/0), len 100, sending [/pre]
注重:
设置BW中的两个错误
1.将两个BW值 一个500000 一个1500,设置variance 为 334,5000000/1500=333,可是经由尝试,variance设置规模为1-128
2.设置BW值不恰当的时辰,可能会导致sh ip route显示possiblydown,这个时辰从头启用IGRP即可
常识点:
IP和谈呈现最早,最大跳数只撑持15跳,只适合小型收集;IGRP是Cisco公司为了填补RIP的缺陷而开发设计,适合更大的收集,最大撑持255跳,为了减轻收集的承担,将默认的更新周期从RIP的30秒改为90秒,可是这也造成了收集拓扑转变时收敛速度变迟缓了。RIP和IGRP都撑持最多达6条等价路由,IGRP还撑持非等价路由,增添了负载平衡的矫捷性。IGRP为Cisco公司所私有,今朝只能在Cisco的路由器上使用。
IGRP默认撑持4条路径的等价的负载平衡,最大撑持6条,IGRP还撑持非等价的负载平衡呼吁maximum-paths x
在IGRP的update包里,把路由条目分为了3个类别,如下:
1.内部路由(interior route):被宣告的路由条目是当地化的
2.系统路由(system route):达到被鸿沟路由器汇总的收集地址的路由
3.外部路由(exterior route):来自外部,好比其他的AS的路由
IGRP Metrics
IGRP的metric是复合性的,4个要素分袂是带宽(bandwidth,BW),延迟(delay),靠得住性(reliability)和负载(load).默认IGRP的metric只以BW和delay作为尺度.其他的2个要素可以经由过程呼吁,设置装备摆设成metric的要素的一部门.有一点要注重的是,虽然IGRP的metric不使用最大传输单元(maximum transmission unit,MTU)作为要素,可是IGRP仍然会对每条路径上最小的MTU进行跟踪.
IGRP Timers and Stability Features
IGRP的update包发送周期为90秒,是RIP的3倍,可是为防止timer的同步,一般这个周期为72到90秒之间的随机数当一条路由初度被进修到往后,这条路由的invalid timer就设置为270秒(RIP的3倍).flush timer被设置为630秒(update发送周期的7倍).每次领受到该路由的update包往后,这些timer城市从头的初始化.如不美观在invalid timer超出,仍然没领受到该路由的update,那么该路由就标识表记标帜为不成达,可是该路由仍然会保留在路由表中,而且以方针不成达的体例宣告出去,直到flush timer超出,该路由就被彻底通衢由表中删除
IGRP使用了3倍于RIP的timer,利益是节约了链路的带宽,可是错误谬误是收敛(convergence)慢于RIP.好比当一台路由器出问题down失踪了IGRP要用3倍于RIP的时刻才能检测到该路由器状况的转变。
当一条路由标识表记标帜为不成达的时辰,或者下一跳的路由器增大了达到方针地址的metric并引起触发更新(triggered update),那么该路由将进入holddown状况,而且holddown timer的长度为3倍update发送时刻再加10秒(280秒).这个时辰,关于方针地址的任何新的信息都不会被接管直到holddown timer超出.可以使用呼吁no metric holddown来封锁这个holddown特征,一般在一个无环路的收集拓扑里,holddown特征是没什么用的,封锁这一特征有助于加速收敛时刻。
