阅读:4412回复:0
[微软考试]MCSE真题]DNS服务逆向查找出错原因解析
更多 发布于:2012-08-22 15:29
You are the administrator of PConline’s network. You configure a Windows 2000 Server computer as the DNS server for your network. You create both standard primary forward lookup and reverse lookup zones.You discover that when you use the nslookup utility, you cannot resolve host names from IP addresses on your network. You also discover that when you run the Tracert.exe utility, you receive the following error message. "Unable to resolve target system name."
What should you do?
A. Configure the DNS to forward requests to an external DNS
B. Install a WINS server and configure DHCP to issue the IP address of the WINS server to all DHCP clients
C. Create PTR (pointer) records in your reverse lookup zone
D. Copy the systemrootsystem32dnscachesamplescache.dns to systemrootsystem32dnscachecache.dns
Select the 1 best answer
  作为一名PConline的网络管理员,你配置了一台Windows 2000 Server作为企业网络的DNS服务器。你创建了标准主区域的正向查找与逆向查找,但你发现当你在局域网络中使用nslookup命令行时,不能够将IP地址解析为主机名称,而当你使用Tracet.exe命令时,收到了这样的提示“Unable to resolve target system name.”
解答:
  Tracert 命令是用来检查通往远程系统的路由状况的,它必需将主机名解析为IP地址以及将IP地址解析为主机名来运行,工具,用于测试或解决 DNS 服务器问题。Nslookup.exe 可以在两种模式下运行:交互式和非交互式。当需要返回单块数据时,请使用非交互式模式。非交互模式的语法如下:
  nslookup [-option] [hostname] [server]
要在交互模式缕舳?Nslookup.exe,只需在命令提示符下输入 nslookup:
  C:> nslookup
  Default Server:  nameserver1.domain.com
  Address:  10.0.0.1
参考资料:
MCSE Trainking Kit -- Microsoft Windows 2000 Network Infrasturucture Administration -- Chapter8 Using the Windows 2000 DNS Server-- Lesson 5 :Monitoring and Troubleshooting DNS
Internet密钥交换鉴别方法
问题:
You are working as a network administrator.You know that Internet Key Exchange (IKE) is the new term for ISAKMP/Oakley.But what are the tree authentication methods you can use with IKE?
A.IPSec AH
B.IPSec ESP
C.Kerberos
D.Pre-shared key
E.X.509 Certificates
F.NTLM
Select the 3 best answers
可以借助IKE使用的三种鉴别方法是什么?
解答:
.Kerberos V5
.X.509 Version3 证书
.预共享密钥(Pre-shared key)
正确答案:CDE
参考资料:
MSEE Training Kit -- Microsoft Windows 2000 Network Infrastructure Administration -- Chapter 10 Securing Network Protocoles
