阅读:2172回复:0
针对ARP攻击的小设置 可以辅助防火墙
更多 发布于:2012-08-23 23:10
以下是可以存为批处理的命令,加入开机启动项即可
@echo off
:::::::::读取本机Mac地址
if exist ipconfig.txt del ipconfig.txt
ipconfig /all >ipconfig.txt
if exist phyaddr.txt del phyaddr.txt
find "Physical Address" ipconfig.txt >phyaddr.txt
for /f "skip=2 tokens=12" %%M in (phyaddr.txt) do set Mac=%%M
:::::::::读取本机ip地址
if exist IPAddr.txt del IPaddr.txt
find "IP Address" ipconfig.txt >IPAddr.txt
for /f "skip=2 tokens=15" %%I in (IPAddr.txt) do set IP=%%I
:::::::::绑定本机IP地址和MAC地址
arp -s %IP% %Mac%
:::::::::读取网关地址
if exist GateIP.txt del GateIP.txt
find "Default Gateway" ipconfig.txt >GateIP.txt
for /f "skip=2 tokens=13" %%G in (GateIP.txt) do set GateIP=%%G
ping %GateIP% -n 1
:::::::::读取网关Mac地址
if exist GateMac.txt del GateMac.txt
arp -a %GateIP% >GateMac.txt
for /f "skip=3 tokens=2" %%H in (GateMac.txt) do set GateMac=%%H
:::::::::绑定网关Mac和IP
arp -s %GateIP% %GateMac%
:::::::::删除临时文件
del GateIP.txt
del GateMac.txt
del IPAddr.txt
del ipconfig.txt
del phyaddr.txt
exit
存为批处理的方法,在记事本中选择另存为 arp.bat即可
如果有人嫌这样麻烦,那么有永久绑定IP的方法,两种方法都可以,根据自身情况选择
