阅读:2792回复:0
能有效防CC攻击的asp脚本
更多 发布于:2012-08-24 21:52
较为全面的asp防CC代码
Dim CC_Info(4),strInfo,strTemp
If Session(“CC_Info”) = “” Then
CC_Info(0) = “cclog.txt” ‘日志文件名
CC_Info(1) = Request.ServerVariables(“HTTP_X_FORWARDED_FOR”)
CC_Info(2) = Request.ServerVariables(“REMOTE_ADDR”)
CC_Info(3) = 10 ‘N秒内禁止刷新当前页面
CC_Info(4) = “badip.txt” ‘IP黑名单文件名
Session(“CC_Info”) = CC_Info(0) ;”|”; CC_Info(1) ;”|”; CC_Info(2) ;”|”; CC_Info(3) ;”|”; CC_Info(4)
Else
strInfo = Split(Session(“CC_Info”),”|”)
CC_Info(0) = strInfo(0)
CC_Info(1) = strInfo(1)
CC_Info(2) = strInfo(2)
CC_Info(3) = strInfo(3)
CC_Info(4) = strInfo(4)
End If
Const chkRefresh = 1 ’ www.atcpu.com 0关闭防刷新
Const chkProxy = 1 ’0关闭代理验证
Const chkBadIP = 1 ’0关闭IP黑名单
If Session(“BadIP”) = “” Then
strInfo = ReadFile(CC_Info(4))
If strInfo = “” Then strInfo = “chinavb.net”
Session(“BadIP”) = strInfo
Else
strInfo = Session(“BadIP”)
End If
‘/*第一层判断,N秒内禁止刷新*/
If chkRefresh = 1 Then
If Session(“RefreshTime”)=”" Then
Session(“RefreshTime”)=Now()
Else
If DateDiff(“s”, Session(“RefreshTime”), Now()) < CInt(CC_Info(3)) Then
Response.Write(“系统繁忙,请稍候再试!错误代码001″)
Response.End()
Else
End If
End If
End If
‘/*第二层判断,代理禁止查看*/
If chkProxy = 1 Then
If CC_Info(1) <> “” Then
If InStr(strInfo,CC_Info(1)) = 0 Then
strTemp = CC_Info(1) ; vbCrLf
If InStr(strInfo,CC_Info(2)) = 0 Then
strTemp = strTemp ; “[" ; CC_Info(2) ; "]” ; vbCrLf
End If
SaveLog CC_Info(4),strTemp
strInfo = strInfo ; strTemp
End If
‘记录CC攻击日志
SaveLog CC_Info(0),CC_Info(1) ; “["; CC_Info(2) ; "]” ; Now() ;vbCrLf
Response.Write(“系统繁忙,请稍候再试!错误代码002″)
Response.End()
End If
End If
‘/*第三层判断,IP黑名单禁止查看*/
If chkBadIP = 1 Then
If InStr(strInfo,CC_Info(2))>0 Then
Response.Write(“系统繁忙,请稍候再试!错误代码003″)
Response.End()
End If
End If
‘ForReading=1,ForWriting=2,ForAppending=8
Function SaveLog(filename, filecontent)
On Error Resume Next
Dim fso, thisfile
filename = Server.MapPath(filename)
Set fso = CreateObject(“Scripting.FileSystemObject”)
If Err <> 0 Then
Response.Write(“写入文件”;filename;”失败,可能您的系统不支持FSO!”)
Response.End()
End If
Set thisfile = fso.OpenTextFile(filename, 8, True)
thisfile.write (filecontent)
thisfile.Close
Set fso = Nothing
End Function
Function ReadFile(filename)
Dim fso, thisfile
If Err <> 0 Then
Response.Write(“读取文件”;filename;”失败,可能您的系统不支持FSO!”)
Response.End()
End If
Set thisfile = fso.OpenTextFile(Server.MapPath(filename), 1, True)
ReadFile = thisfile.ReadAll
thisfile.Close
Set thisfile = Nothing
Set fso = Nothing
End Function
