阅读:4700回复:0
win7 64位右键添加显示隐藏系统文件和文件扩展名方法
更多 发布于:2012-08-26 14:37
一、新建一个文档,输入如下代码并另存为:SuperHidden.reg
01
REGEDIT4
02
[HKEY_CLASSES_ROOTDirectoryBackgroundshellexContextMenuHandlersSuperHidden]
03
@="{00000000-0000-0000-0000-000000000012}"
04
[HKEY_CLASSES_ROOTCLSID{00000000-0000-0000-0000-000000000012}InProcServer32]
05
@=hex(2):25,53,79,73,74,65,6d,52,6f,6f,74,25,5c,73,79,73,74,65,6d,33,32,5c,73,
06
68,64,6f,63,76,77,2e,64,6c,6c,00
07
"ThreadingModel"="Apartment"
08
[HKEY_CLASSES_ROOTCLSID{00000000-0000-0000-0000-000000000012}Instance]
09
"CLSID"="{3f454f0e-42ae-4d7c-8ea3-328250d6e272}"
10
[HKEY_CLASSES_ROOTCLSID{00000000-0000-0000-0000-000000000012}InstanceInitPropertyBag]
11
"method"="ShellExecute"
12
"Param1"="SuperHidden.vbs"
13
"command"="显示/隐藏系统文件+扩展名"
14
"CLSID"="{13709620-C279-11CE-A49E-444553540000}"
15
[HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionExplorerAdvanced]
16
"ShowSuperHidden"=dword:00000000
17
"Hidden"=dword:00000002
二、在新建一个文档,输入代码后另存为:SuperHidden.vbs
01
'Show/Hide System Files
02
Dim WSHShell
03
Set WSHShell = WScript.CreateObject("WScript.Shell")
04
sTitle1 = "SSH=0"
05
sTitle2 = "SSH=1"
06
if WSHShell.RegRead("HKCUSoftwareMicrosoftWindowsCurrentVersionExplorerAdvancedShowSuperHidden") = 1 then
07
WSHShell.RegWrite "HKCUSoftwareMicrosoftWindowsCurrentVersionExplorerAdvancedShowSuperHidden", "0", "REG_Dword"
08
WSHShell.RegWrite "HKCUSoftwareMicrosoftWindowsCurrentVersionExplorerAdvancedHidden", "2", "REG_Dword"
09
WSHShell.RegWrite "HKCUSoftwareMicrosoftWindowsCurrentVersionExplorerAdvancedHideFileExt", "1", "REG_Dword"
10
WSHShell.RegWrite "HKCRCLSID{00000000-0000-0000-0000-000000000012}InstanceInitPropertyBagcommand", "显示系统文件+扩展名", "REG_SZ"
11
WSHShell.SendKeys "{F5}+{F10}e"
12
'WSHShell.Popup "Poof, they're gone!", 1, sTitle1, vbInformation
13
else
14
WSHShell.RegWrite "HKCUSoftwareMicrosoftWindowsCurrentVersionExplorerAdvancedShowSuperHidden", "1", "REG_Dword"
15
WSHShell.RegWrite "HKCUSoftwareMicrosoftWindowsCurrentVersionExplorerAdvancedHidden", "1", "REG_Dword"
16
WSHShell.RegWrite "HKCUSoftwareMicrosoftWindowsCurrentVersionExplorerAdvancedHideFileExt", "0", "REG_Dword"
17
WSHShell.RegWrite "HKCRCLSID{00000000-0000-0000-0000-000000000012}InstanceInitPropertyBagcommand", "隐藏系统文件+扩展名", "REG_SZ"
18
19
'WSHShell.Popup "Here they are!", 1, sTitle2, vbInformation
20
end if
21
Set WSHShell = Nothing
22
WScript.Quit(0)
三、将SuperHidden.vbs拷贝到C盘windows目录下即可,然后双击SuperHidden.reg修改注册表,最后重启一下电脑就可以了(如果安装的杀毒软件弹出阻止对话框时,请勾上总是允许,并将下方的以后总是允许的勾勾上就可以了)。
