阅读:2839回复:0
如何在另一台Windows 8 PC 上安装此前从商店购买过的应用
更多 发布于:2012-08-26 15:50
[backcolor=transparent][backcolor=transparent]在其他 PC 上安装这些应用程序按照以下步骤操作即可:
    [backcolor=transparent][backcolor=transparent][backcolor=transparent]1.[backcolor=transparent] [backcolor=transparent]首先,登录另一台 [backcolor=transparent]Windows 8 PC[backcolor=transparent]并启动商店。[backcolor=transparent][backcolor=transparent]
    [backcolor=transparent][backcolor=transparent][backcolor=transparent]2.[backcolor=transparent] [backcolor=transparent]然后使用[backcolor=transparent]“[backcolor=transparent][backcolor=transparent]Windows[backcolor=transparent]键[backcolor=transparent] + I[backcolor=transparent]”(“[backcolor=transparent]i[backcolor=transparent]”[backcolor=transparent]键[backcolor=transparent],[backcolor=transparent]而非小写的[backcolor=transparent]“[backcolor=transparent]L[backcolor=transparent]”),[backcolor=transparent]或使用[backcolor=transparent]“[backcolor=transparent]设置[backcolor=transparent]”[backcolor=transparent]个性分类以确保商店的[backcolor=transparent][backcolor=transparent]Windows Live ID [backcolor=transparent]与在原来[backcolor=transparent] PC [backcolor=transparent]上购买应用程序所使用的[backcolor=transparent][backcolor=transparent]Windows Live ID [backcolor=transparent]相同。
    [backcolor=transparent][backcolor=transparent][backcolor=transparent]3.[backcolor=transparent] [backcolor=transparent]然后,使用“搜索”或浏览找到您想要安装的应用。[backcolor=transparent][backcolor=transparent]
    [backcolor=transparent][backcolor=transparent][backcolor=transparent]4.[backcolor=transparent] [backcolor=transparent]打开应用的[backcolor=transparent]产品描述页面[backcolor=transparent] (PDP)[backcolor=transparent]并单击“安装”按钮安装该应用。
    [backcolor=transparent][backcolor=transparent]注意[backcolor=transparent]:[backcolor=transparent]此方法适用于[backcolor=transparent] [backcolor=transparent]1[backcolor=transparent]至[backcolor=transparent] 5 [backcolor=transparent]台[backcolor=transparent] [backcolor=transparent]PC[backcolor=transparent]。要在第[backcolor=transparent] 6[backcolor=transparent]台[backcolor=transparent] PC [backcolor=transparent]上安装应用程序,需要使用新的[backcolor=transparent] Windows Live ID[backcolor=transparent]并且要重新购买该应用以获取另外[backcolor=transparent] 5 [backcolor=transparent]台[backcolor=transparent] PC [backcolor=transparent]的许可证。在商店中使用的[backcolor=transparent] Windows Live ID [backcolor=transparent]帐户最多可启用[backcolor=transparent] 5[backcolor=transparent]台[backcolor=transparent] PC [backcolor=transparent]的许可证。
因Windows 8还未发布正式版本,此设置适用于Windows 8 客户体验版
