阅读:1997回复:0
解决secureCRT下vi代码高亮问题
更多 发布于:2012-08-27 14:53
用secureCRT终端连接服务器时,用vi编辑代码,显示的颜色是只有黑白两色,看起来灰常蛋疼,search了一下,改一下vi ~/.vimrc里面的配置就可以了,这是一个用于配置vi的文件
代码如下:
Vi代码
set nocp
set ru
set nonu
"set cin
"set cino = :0g0t0(sus
set sm
set ai
set sw=4
set ts=4
set noet
set lbr
set hls
"set backspace = indent , eol , start
"set whichwrap = b , s , < , > , [ , ]
"set fo+ = mB
set selectmode =
"set mousemodel=popup
set keymodel =
"set selection = inclusive
"set matchpairs+ =
syntax on
set hlsearch
highlight Search term=reverse ctermbg=4 ctermfg=7
highlight Normal ctermbg=black ctermfg=white
highlight Comment ctermfg=blue
set cin
"colo ron
filetype on
保存后断开重连就可以了
