阅读:1852回复:0
ubuntu telnet客户端的启动
更多 发布于:2012-08-27 15:00
1. sudo apt-get install xinetd telnetd
2. 安装成功后,系统也会有相应提示,
sudo vi /etc/inetd.conf并加入以下一行
telnet stream tcp nowait telnetd /usr/sbin/tcpd /usr/sbin/in.telnetd
3. sudo vi /etc/xinetd.conf并加入以下内容:
# Simple configuration file for xinetd
#  www.atcpu.com
# Some defaults, and include /etc/xinetd.d/
defaults
# Please note that you need a log_type line to be able to use
log_on_success
# and log_on_failure. The default is the following :
# log_type = SYSLOG daemon info
instances = 60
log_type = SYSLOG authpriv
log_on_success = HOST PID
log_on_failure = HOST
cps = 25 30
includedir /etc/xinetd.d
4. sudo vi /etc/xinetd.d/telnet并加入以下内容:
# default: on
# description: The telnet server serves telnet sessions; it uses \
# unencrypted username/password pairs for authentication.
service telnet
disable = no
flags = REUSE
socket_type = stream
wait = no  www.atcpu.com
user = root
server = /usr/sbin/in.telnetd
log_on_failure += USERID
5. 重启机器或重启网络服务sudo /etc/init.d/xinetd restart
6. 使用TELNET客户端远程登录即可进行非root用户访问。
7.使用root登录: mv /etc/securetty /etc/securetty.bak 这样root可以登录
了。
也可这样:
修改/etc/pam.d/login这个文件。只需将下面一行注释掉即可。
#auth required lib/security/pam_securetty.so
