µÆ»ð»¥Áª
¹ÜÀíÔ±
¹ÜÀíÔ±
  • ×¢²áÈÕÆÚ2011-07-27
  • ·¢ÌûÊý41778
  • »ð±Ò41290ö
  • ·ÛË¿1086
  • ¹Ø×¢100
  • ÖÕÉí³É¾Í½±
  • ×ɳ·¢
  • ÖÒʵ»áÔ±
  • ¹àË®Ìì²Å½±
  • Ìùͼ´óʦ½±
  • Ô­´´ÏÈ·æ½±
  • ÌØÊâ¹±Ï×½±
  • Ðû´«´óʹ½±
  • ÓÅÐã°ßÖñ½±
  • ÉçÇøÃ÷ÐÇ
ÔĶÁ£º2037»Ø¸´£º0
Ubuntu aptÃüÁî²ÎÊýÏê½â
Â¥Ö÷#
¸ü¶à ·¢²¼ÓÚ£º2012-08-27 15:03
    apt-cache search package ËÑË÷°ü
    apt-cache show package »ñÈ¡°üµÄÏà¹ØÐÅÏ¢£¬Èç˵Ã÷¡¢´óС¡¢°æ±¾µÈ
    sudo apt-get install package °²×°°ü
    sudo apt-get install package - - reinstall ÖØÐ°²×°°ü
    sudo apt-get -f install ÐÞ¸´°²×°"-f = ¡ª¡ªfix-missing"
    sudo apt-get remove package Ð¶ÔØÒ»¸öÒѰ²×°µÄÈí¼þ°ü£¨±£ÁôÅäÖÃÎļþ£©     sudo apt-get check ¼ì²éÊÇ·ñÓÐË𻵵ÄÒÀÀµ
    sudo apt-get remove package - - purge ɾ³ý°ü£¬°üÀ¨É¾³ýÅäÖÃÎļþµÈ
    sudo apt-get update ¸üÐÂÔ´
    sudo apt-get upgrade ¸üÐÂÒѰ²×°µÄ°ü
    sudo apt-get dist-upgrade Éý¼¶ÏµÍ³ÄÚºË
    sudo apt-get dselect-upgrade ʹÓà dselect Éý¼¶
    sudo apt-get build-dep package °²×°Ïà¹ØµÄ±àÒë»·¾³
    sudo apt-get source package ÏÂÔØ¸Ã°üµÄÔ´´úÂë
    sudo apt-get autoclean apt»á°ÑÒÑ×°»òÒÑжµÄÈí¼þ¶¼±¸·ÝÔÚÓ²ÅÌÉÏ£¬ËùÒÔÈç¹ûÐèÒª¿Õ¼äµÄ»°£¬¿ÉÒÔÈÃÕâ¸öÃüÁîÀ´É¾³ýÄãÒѾ­É¾µôµÄÈí¼þ
    sudo apt-get clean ;; sudo apt-get autoclean ÇåÀíÎÞÓõİü
    sudo apt-cache depends package Á˽âʹÓÃÒÀÀµ
    sudo apt-cache rdepends package ÊDz鿴¸Ã°ü±»ÄÄЩ°üÒÀÀµ
    sudo apt-cache search package ÔÚÈí¼þ°üÁбíÖÐËÑË÷¸Ã°üÃû
    suco apt-cache show package ÏÔʾ¸ÃÈí¼þ°üÐÅÏ¢¡£
    apt-cache dumpavail  ´òÓ¡¿ÉÓÃÈí¼þ°üÁÐ±í¡£
    dpkg -S file  Õâ¸öÎļþÊôÓÚÄĸöÒѰ²×°Èí¼þ°ü¡£
    dpkg -L package  ÁгöÈí¼þ°üÖеÄËùÓÐÎļþ¡£
    dpkg ¨Cforce-all ¨cpurge packagename ÓÐЩÈí¼þºÜÄÑÐ¶ÔØ£¬¶øÇÒ»¹×èÖ¹Á˱ðµÄÈí¼þµÄÓ¦Ó㬾ͿÉÒÔÓÃÕâ¸ö
    dpkg -l package-name-pattern ÁгöËùÓÐÓëģʽÏàÆ¥ÅäµÄÈí¼þ°ü¡£Èç¹ûÄú²»ÖªµÀÈí¼þ°üµÄÈ«Ãû£¬Äú¿ÉÒÔʹÓá°*package-name-pattern*¡±
    apt-file search filename  ²éÕÒ°üº¬Ìض¨ÎļþµÄÈí¼þ°ü£¨²»Ò»¶¨ÊÇÒѰ²×°µÄ£©£¬ÕâЩÎļþµÄÎļþÃûÖк¬ÓÐÖ¸¶¨µÄ×Ö·û´®¡£apt-fileÊÇÒ»¸ö¶ÀÁ¢µÄÈí¼þ°ü¡£Äú±ØÐë ÏÈʹÓÃapt-get installÀ´°²×°Ëü£¬È»ááÔËÐÐapt-file update¡£Èç¹ûapt-file search filenameÊä³öµÄÄÚÈÝÌ«¶à£¬Äú¿ÉÒÔ³¢ÊÔʹÓÃapt-file search filename | grep -w filename£¨Ö»ÏÔʾָ¶¨×Ö·û´®×÷ΪÍêÕûµÄµ¥´Ê³öÏÖÔÚÆäÖеÄÄÇЩÎļþÃû£©»òÕßÀàËÆ·½·¨£¬ÀýÈ磺apt-file search filename | grep /bin/£¨Ö»ÏÔʾλÓÚÖîÈç/bin»ò/usr/binÕâЩÎļþ¼ÐÖеÄÎļþ£¬Èç¹ûÄúÒª²éÕÒµÄÊÇij¸öÌØ¶¨µÄÖ´ÐÐÎļþµÄ»°£¬ÕâÑù×öÊÇÓаïÖúµÄ£©¡£     aptitude¡ª¡ªÏêϸ²é¿´ÒѰ²×°»ò¿ÉÓõÄÈí¼þ°ü¡£Óëapt-getÀàËÆ£¬aptitude¿ÉÒÔͨ¹ýÃüÁîÐз½Ê½µ÷Ó㬵«½öÏÞÓÚijЩÃüÁ¡ª×î³£¼ûµÄÓа²×°ºÍÐ¶ÔØÃüÁî¡£ÓÉÓÚaptitude±Èapt-getÁ˽â¸ü¶àÐÅÏ¢£¬¿ÉÒÔ˵Ëü¸üÊʺÏÓÃÀ´½øÐа²×°ºÍÐ¶ÔØ¡£
    sudo apt-get autoclean¡ª¡ª¶¨ÆÚÔËÐÐÕâ¸öÃüÁîÀ´Çå³ýÄÇЩÒѾ­Ð¶ÔصÄÈí¼þ°üµÄ.debÎļþ¡£Í¨¹ýÕâÖÖ·½Ê½£¬Äú¿ÉÒÔÊÍ·Å´óÁ¿µÄ´ÅÅ̿ռ䡣Èç¹ûÄúµÄÐèÇóÊ®·ÖÆÈÇУ¬¿É ÒÔʹÓÃapt-get cleanÒÔÊͷŸü¶à¿Õ¼ä¡£Õâ¸öÃüÁî»á½«ÒѰ²×°Èí¼þ°ü¹üµÄ.debÎļþÒ»²¢É¾³ý¡£´ó¶àÊýÇé¿öÏÂÄú²»»áÔÙÓõ½ÕâЩ.debsÎļþ¡£
ϲ»¶0 ÆÀ·Ö0
ÓοÍ
·µ»Ø¶¥²¿
