阅读:2545回复:0
Centos自动登陆命令
更多 发布于:2012-08-27 15:07
Centos自动登陆命令
主要是修改/etc/gdm/custom.conf,添加AutomaticLogin和TimedLogin 重启即可。
vim /etc/gdm/custom.conf
[daemon]
AutomaticLoginEnable=true #设置系统自动登陆为可用
AutomaticLogin=username #这里改为你要知动登陆的用户名
TimedLoginEnable=true  #
TimedLogin=username #同样将这里修改为你需要登陆的用户名
TimedLoginDelay=7
/*如果这个地方是个空白,则把上面的代码全给填上*/
[security]
AllowRoot=false
[xdmcp]
[gui]
[greeter]
DefaultWelcome=false
Welcome=Wait seconds...
Logo=/usr/share/pixmaps/faces/penguin.jpg
[chooser]
[debug]
# Note that to disableservers defined in the defaults.conf file (such as
# 0=Standard, youmust put a line in this file that says 0=inactive, as
# described inthe Configuration section of the GDM documentation.
[servers]
# Also note, that if you redefine a [server-foo]section, then GDM will
# use the definition in this file, not thedefaults.conf file.  It is
# currently not possible to disable a[server-foo] section defined
# in the defaults.conf file.
[server-Chooser]
name=Chooser server
command=/usr/bin/Xorg -audit 0
chooser=false
handled=true
flexible=false
priority=0
