阅读:5928回复:0
[BIOS技术]Bios基础:BIOS常见词语
更多 发布于:2012-08-28 13:22
MRH-R(Memory Repeater Hub,内存数据处理中心)
MRH-S(SDRAM Repeater Hub,SDRAM数据处理中心)
MTH(Memory Transfer Hub,内存转换中心)
NGIO(Next Generation Input/Output,新一代输入/输出标准)
P64H(64-bit PCI Controller Hub,64位PCI控制中心)
PCB(printed circuit board,印刷电路板)
PCBA(Printed Circuit Board Assembly,印刷电路板装配)
PCI: Peripheral Component interconnect,互连外围设备
PCI SIG(Peripheral Component Interconnect Special Interest Group,互连外围设备专业组)
POST(Power On Self Test,加电自测试)
RNG(Random number Generator,随机数字发生器)
RTC: Real Time Clock(实时时钟)
KBC(KeyBroad Control,键盘控制器)
SAP(Sideband Address Port,边带寻址端口)
SBA(Side Band Addressing,边带寻址)
SMA: Share Memory Architecture,共享内存结构
STD(Suspend To Disk,磁盘唤醒)
STR(Suspend To RAM,内存唤醒)
SVR: Switching Voltage Regulator(交换式电压调节)
USB(Universal Serial Bus,通用串行总线)
USDM(Unified System Diagnostic Manager,统一系统监测管理器)
VID(Voltage Identification Definition,电压识别认证)
VRM (Voltage Regulator Module,电压调整模块)
ZIF: Zero Insertion Force, 零插力
主板技术
Gigabyte
ACOPS: Automatic cpu OverHeat Prevention System(CPU过热****系统)
SIV: System Information Viewer(系统信息观察)
磐英
ESDJ(Easy Setting Dual Jumper,简化CPU双重跳线法)
浩鑫
UPT(USB、PANEL、LINK、TV-OUT四重接口)
芯片组
ACPI(Advanced Configuration and Power Interface,先进设置和电源管理)
AGP(Accelerated Graphics Port,图形加速接口)
I/O(Input/Output,输入/输出)
MIOC: Memory and I/O Bridge Controller,内存和I/O桥控制器
NBC: North Bridge Chip(北桥芯片)
PIIX: PCI ISA/IDE Accelerator(加速器)
PSE36: Page Size Extension 36-bit,36位页面尺寸扩展模式
PXB: PCI Expander Bridge,PCI增强桥
RCG: RAS/CAS Generator,RAS/CAS发生器
SBC: South Bridge Chip(南桥芯片)
SMB: System Management Bus(全系统管理总线)
SPD(Serial Presence Detect,内存内部序号检测装置)
SSB: Super South Bridge,超级南桥芯片
TDP: Triton Data Path(数据路径)
TSC: Triton System Controller(系统控制器)
QPA: Quad Port Acceleration(四接口加速)
