阅读:2677回复:0
[mysql]mysql服务端编码设置
更多 发布于:2012-09-01 02:12
安装完mysql,启动后发现服务器默认使用的是lat1编码.
具体操作和查看过程如下:
启动方式: /etc/init.d/mysql.server start
效果:
Database changed
mysql> status
mysql  Ver 14.12 Distrib 5.0.77, for redhat-linux-gnu (x86_64) using readline 5.1
Connection id:        8
Current database:    demodb
Current user:        root@localhost
SSL:            Not in use
Current pager:        stdout
Using outfile:        ''
Using delimiter:    ;
Server version:        5.5.21 MySQL Community Server (GPL)
Protocol version:    10
Connection:        Localhost via UNIX socket
Server characterset:    latin1
Db     characterset:    utf8
Client characterset:    latin1
Conn.  characterset:    latin1
UNIX socket:        /var/lib/mysql/mysql.sock
Uptime:            33 sec
Threads: 7  Questions: 137  Slow queries: 0  Opens: 83  Flush tables: 1  Open tables: 76  Queries per second avg: 4.151
mysql>
启动方式: /etc/init.d/mysql.server start --character-set-server=utf8
效果:
mysql> use demodb;
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Database changed
mysql> status;
Connection id:        4
SSL:            Not in use
Using outfile:        ''
Using delimiter:    ;
Server characterset:    utf8
Uptime:            1 min 15 sec
Threads: 4  Questions: 131  Slow queries: 0  Opens: 84  Flush tables: 1  Open tables: 77  Queries per second avg: 1.746
mysql>
这种方式,在每次启动的时候都需要指定编码参数.否则服务器就使用的是系统默认的lat1编码.
另外一种方法是:
mysql>set character_set_server=utf8;
这种方法我也试了,不行,再重新登录客户端后,就又恢复了原来的编码.理由很简单,系统启动的时候用的不是utf8编码.
一劳永逸的办法,就是通过修改配置文件实现.
# vim /etc/my.cnf
内容如下:
[mysqld]
datadir=/var/lib/mysql
socket=/var/lib/mysql/mysql.sock
user=mysql
#添加下面的红字内容
# Default to using old password format for compatibility with mysql 3.x
# clients (those using the mysqlclient10 compatibility package).
old_passwords=1
[mysqld_safe]
log-error=/var/log/mysqld.log
pid-file=/var/run/mysqld/mysqld.pid
                           版权声明  版权所有@zhyiwww
