阅读:2145回复:0
[mysql]linux备份Mysql数据库shell
更多 发布于:2012-09-01 02:15
欢迎拍砖,详细内容如下:
# MYSQL 数据文件路径
MYSQL_DATA_PATH="/usr/local/mysql/data/"
# 备份目录
MYSQL_DUMP_PATH="***/DB/"
# 备份用户名
MYSQL_ACCOUNT="mysql_backup"
# 备份密码
MYSQL_PASSword="mysql_backup"
MYSQLDUMP_OPTS="mysqldump -u$MYSQL_ACCOUNT -p$MYSQL_PASSword --single-transaction"
# 压缩命令  bzip2 -k 保留源文件
TAR_OPTS="bzip2 "
# 单个数据库进行备份
function BackDB(){
        FULLPATH="$1"
        #遍历目录
        for dbName in $(/bin/ls $FULLPATH)
        do
                # check is database
                fileType=`/usr/bin/file $FULLPATH$dbName | /bin/awk '{FS=":"} {printf $2}'`
                # 文件夹的类型为directory
                if [ "directory" == $fileType ]; then
                        # start dump
                        if [ "$dbName" == "mysql" ] \
                                || [ "$dbName" == "test" ] \
                                || [ "$dbName" == "information_schema" ] \
                                || [ "$dbName" == "performance_schema" ]; then
                                echo "------------->$dbName not need dump!!"
                        else
                                echo $dbName
                                dumpName=$MYSQL_DUMP_PATH/"$dbName"_"$DATESTR"
                                $MYSQLDUMP_OPTS $dbName > "$dumpName".sql
                                # 压缩备份档
                                $TAR_OPTS "$BACKUP_NAME".sql
                        fi
                else
                        printf '%s is not database            ######## \n' $dbName
                fi
        done
# 每个数据表单独备份
function BackDBTB(){
        FULLPATH="$1"
        #遍历目录
        for fName in $(/usr/bin/find $FULLPATH -name "*.ibd")
        do
                dbPath=`echo "$fName" | /bin/awk 'BEGIN {FS="'$FULLPATH'"} {printf $2}'`
                # get database name
                dbName=`echo "$dbPath" | /bin/awk 'BEGIN {FS="/"} {printf $1}'`
                # get table name
                tbName=`echo "$dbPath" | /bin/awk 'BEGIN {FS="/"} {printf $2}'`
                # start dump
                if [ "$dbName" == "mysql" ]\
                else
                        echo $dbName $tbName
                         dumpName=$MYSQL_DUMP_PATH/"$dbName"_"$tbName"_"$DATESTR"
                        $MYSQLDUMP_OPTS $dbName $tbName > "$dumpName".sql
                        # 压缩备份档
                        $TAR_OPTS "$dumpName".sql
                fi
        done
作者 babaoqi
