阅读:2033回复:0
[mysql]非正常关机时,innodb故障导致mysql无法启动的解决方法
更多 发布于:2012-09-01 02:15
一次非正常关机,mysql无法启动。查看err日志,显示:
InnoDB: Starting crash recovery.
InnoDB: Reading tablespace information from the .ibd files...
InnoDB: Restoring possible half-written data pages from the doublewrite
InnoDB: buffer...
InnoDB: Error: trying to access page number 4294899072 in space 0,
InnoDB: space name ./ibdata1,
InnoDB: which is outside the tablespace bounds.
InnoDB: Byte offset 0, len 16384, i/o type 10.
InnoDB: If you get this error at mysqld startup, please check that
InnoDB: your my.cnf matches the ibdata files that you have in the
InnoDB: MySQL server.
120331 1:03:41 InnoDB: Assertion failure in thread 3078932288 in file fil0fil.c line 4409
InnoDB: We intentionally generate a memory trap.
InnoDB: Submit a detailed bug report to http://bugs.mysql.com.
InnoDB: If you get repeated assertion failures or crashes, even
InnoDB: immediately after the mysqld startup, there may be
InnoDB: corruption in the InnoDB tablespace. Please refer to
InnoDB: http://dev.mysql.com/doc/refman/5.5/en/forcing-innodb-recovery.html
InnoDB: about forcing recovery.
21:03:41 UTC - mysqld got signal 6 ;
没办法,只好在/etc/my.cnf中写入
[mysqld] innodb_force_recovery = 4
但是仍然无法启动。
改为:innodb_force_recovery = 6
数据库可以读出来,在6的情况下,是无法修改数据库的,也无法插入,只能导出。
用mysqldump导出,再把innodb_force_recovery改为0,但是数据无法导入。
最后还是删除了数据库重建。
这是第二次遇到这种错误,标记一下。
