阅读:2578回复:0
[mysql]MYSQL delete语句不支持别名的问题
更多 发布于:2012-09-01 02:17
有一个表的数据比较大,然后需要进行关联删除,删除的时候发现如下SQL报错:
DELETE FROM test.test1 a WHERE EXISTS (SELECT 1 FROM test.test2 b WHERE a.recordID=b.smsInfoID AND b.receiveTime <="2011-10-09 00:00:00" ) limit 1000;
报错如下:
Error Code: 1064
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'a WHERE EXISTS (SELECT 1 FROM test.test2 b WHERE a.recordID=b.smsInf' at line 1  开始以为是exists的问题,于是更改成in再测试,也报同样错:
DELETE FROM test.test1 a WHERE a.recordid IN (SELECT b.smsInfoID FROM test.test2 b WHERE b.receiveTime <= "2011-10-09 00:00:00") LIMIT 1000;
原来是MYSQL的delete语句不支持别名!
将别名去掉就可以了,将上面两个报错的SQL更改成如下形式就可以了:
DELETE FROM test.test1 WHERE recordid IN (SELECT smsInfoID FROM test.test2 WHERE receiveTime <= "2011-10-09 00:00:00") LIMIT 1000;  DELETE FROM test.test1 WHERE EXISTS (SELECT 1 FROM test.test2 WHERE test1.recordID=test2.smsInfoID AND test2.receiveTime <= "2011-10-09 00:00:00") LIMIT 1000;
