阅读:2511回复:0
[SQL Server]sql server 通用分页存储过程(sql sever 2005以上)
更多 发布于:2012-09-04 18:03
create PROCEDURE [dbo].[GetPageChangingTableByRowNumber]
@Field nvarchar(1000),
@TableName  nvarchar(100),
@condition  nvarchar(1000),--格式为:and (查询条件)  如'and (key=value and key1=value1)'
    @OrderField nvarchar(100),
    @OrderType int,
    @pageindx int,
@PageSize  int,
    @RecordCount int output     --记录的总数
as
BEGIN
--判断是否有排序字段
    if(@OrderField is null or ltrim(rtrim(@OrderField))='')
     begin
            RAISERROR('排序字段不能为空',16,1)
            return
     end
    --组装order语句
    declare @temp nvarchar(200)
    set @temp=' order by '+@OrderField
if(@OrderType=1)
  begin
     set @temp=@temp+' asc '
        end
     else
  begin
     set @temp=@temp+' desc '
        end
    --组装查询条件,如果没有查询条件,直接跳过
   if(@condition is not null and ltrim(rtrim(@condition))!='')
   begin
             set @condition='where 1=1'+@condition
  end
else
    begin
    set @condition=''
    end
--求记录的总数
    declare @Countsql  nvarchar(max)
set @Countsql='select @a= count(1) from '+@TableName +' '+@condition
    exec  sp_executesql  @Countsql,N'@a int output',@RecordCount output
    print  @RecordCount
    declare @sql  nvarchar(max)
--分页
if(@pageindx=1)
  begin
   set @sql=' select top '+cast(@pagesize as nvarchar )+'  '+ @Field+' from '+@TableName +' '+@condition+' '+@temp
  end
else
  begin
       declare @startNumber   int
       set @startNumber =(@pageindx-1)*@pagesize
    set @sql='select ROW_NUMBER() over('+@temp+') as number, '+@Field+' from '+@TableName+'  '+@condition
    set @sql='SET ROWCOUNT '+Convert(varchar(4),@PageSize)+'; WITH SP_TABLE AS('+@sql   +')  SELECT '+@Field+' from SP_TABLE   where  number>'+CAST(@startNumber as nvarchar)
  end
    print @sql
exec(@sql)
END
