阅读:3393回复:0
[SQL Server]SQL 2008 R2索引的重建
更多 发布于:2012-09-04 18:05
项目升级数据库由SQL2000升级到2008R2,今天对数据库表进行碎片扫描,发现有些表碎片较大,于是决定重建索引,联机帮助是最好的老师,将相关脚本摘录备后查。
参考sys.dm_db_index_physical_stats
检查索引碎片情况
SELECT
    OBJECT_NAME(object_id) as objectname,
    object_id AS objectid,  www.atcpu.com
    index_id AS indexid,
    partition_number AS partitionnum,
    avg_fragmentation_in_percent AS fra
FROM sys.dm_db_index_physical_stats (DB_ID(), NULL, NULL , NULL, 'LIMITED')
WHERE avg_fragmentation_in_percent > 10.0 AND index_id > 0;
使用脚本中的 sys.dm_db_index_physical_stats 重新生成或重新组织索引 (来源于联机帮助)
SET NOCOUNT ON;
DECLARE @objectid int;
DECLARE @indexid int;
DECLARE @partitioncount bigint;
DECLARE @schemaname nvarchar(130);
DECLARE @objectname nvarchar(130);
DECLARE @indexname nvarchar(130);
DECLARE @partitionnum bigint;
DECLARE @partitions bigint;
DECLARE @frag float;  www.atcpu.com
DECLARE @command nvarchar(4000);
-- Conditionally select tables and indexes from the sys.dm_db_index_physical_stats function
-- and convert object and index IDs to names.
SELECT
    avg_fragmentation_in_percent AS frag
INTO #work_to_do
-- Declare the cursor for the list of partitions to be processed.
DECLARE partitions CURSOR FOR SELECT * FROM #work_to_do;
-- Open the cursor.
OPEN partitions;
-- Loop through the partitions.
WHILE (1=1)
    BEGIN;
        FETCH NEXT
           FROM partitions
           INTO @objectid, @indexid, @partitionnum, @frag;
        IF @@FETCH_STATUS < 0 BREAK;
        SELECT @objectname = QUOTENAME(o.name), @schemaname = QUOTENAME(s.name)
        FROM sys.objects AS o  www.atcpu.com
        JOIN sys.schemas as s ON s.schema_id = o.schema_id
        WHERE o.object_id = @objectid;
        SELECT @indexname = QUOTENAME(name)
        FROM sys.indexes
        WHERE  object_id = @objectid AND index_id = @indexid;
        SELECT @partitioncount = count (*)
        FROM sys.partitions
-- 30 is an arbitrary decision point at which to switch between reorganizing and rebuilding.
        IF @frag < 30.0
            SET @command = N'ALTER INDEX ' + @indexname + N' ON ' + @schemaname + N'.' + @objectname + N' REORGANIZE';
        IF @frag >= 30.0
            SET @command = N'ALTER INDEX ' + @indexname + N' ON ' + @schemaname + N'.' + @objectname + N' REBUILD';
        IF @partitioncount > 1
            SET @command = @command + N' PARTITION=' + CAST(@partitionnum AS nvarchar(10));  www.atcpu.com
        EXEC (@command);
        PRINT N'Executed: ' + @command;
    END;
-- Close and deallocate the cursor.
CLOSE partitions;
DEALLOCATE partitions;
-- Drop the temporary table.
DROP TABLE #work_to_do;
GO
作者 Shijun.Huang.HI
