阅读:2749回复:0
[SQL Server]SQL Server中trigger和变量的使用笔记
更多 发布于:2012-09-04 18:06
[sql]
--用trigger插入主键的值
--通过时间变量来决定主键的值
create trigger ss on test
instead of insert --在插入之前执行此trigger
as
begin
    declare @index varchar(30)  --声明变量
    waitfor delay '00:00:00.010'    --延时0.01秒执行下一条指令
    set @index = replace(replace(replace(replace(convert(varchar(23),
getdate(),121),'-',''),' ',''),':',''),'.','') --将当前时间转化为字符串
    insert into test
    select @index,i.SNAME,i.STATUS,i.CITY
    from inserted i
end   www.atcpu.com
insert into test(SNAME,STATUS,CITY) values ('11',30,'ss');
drop trigger ss;
delete from test
select * from test
   www.atcpu.com
--测试变量的用法
declare @a numeric
set @a = cast(replace(replace(replace(replace(convert(varchar(23),getdate(),121),'-',''),' ',''),':',''),'.','') as numeric)
print @a
print convert(varchar,(@a +1))
--另一种方法使用变量
set @index = replace(replace(replace(replace(convert(varchar(23),getdate(),121),'-',''),' ',''),':',''),'.','') --将当前时间转化为字符串
print @index
