阅读:2489回复:0
[SQL Server]MSSql表列拼接成字符串简析
更多 发布于:2012-09-04 18:07
MSSql表列拼接成字符串简析
将表列拼接成字符串。闲话不多说切入正题,看代码:
[sql]
select  STUFF(
        REPLACE(    www.atcpu.com
            REPLACE(
                (select  fieldName as pc from cj_datadictionary as N
                join [CSD_ORD_PayMent]  on costsid=fieldCode and fieldType='OP' where memberid=72157 and groupID='201205DD2119416553' and [Expenditure]>0
                FOR XML AUTO),'<N pc="','+'
        ),1,1,''
第一步:将表转化为xml格式
[sql]
FOR XML AUTO    www.atcpu.com
第二步:替换<N pc=" 注:N是表名,pc是列名
[sql]
select REPLACE((select  fieldName as pc from cj_datadictionary as N
FOR XML AUTO),'<N pc="','+')
第三步:替换 "/> 注:每项都会以“<表 字段”开始,以“ "/>”结束
[sql]
select REPLACE(REPLACE((select  fieldName as pc from cj_datadictionary as N
FOR XML AUTO),'<N pc="','+'),'"/>','')
最后使用:STUFF() 函数作用:删除指定长度的字符,并在指定的起点上插入另外的字符串
[sql]
select  STUFF(
            REPLACE(
        ),1,1,''
作者 zhengdjin
