阅读:2856回复:0
[SQL Server]SQL快速生成汉字的首拼字母
更多 发布于:2012-09-04 18:07
SQL快速生成汉字的首拼字母
经常要对姓名按拼音搜索。
所以需要做如下函数来快速获取首拼
代码如下:
[sql]
USE [tempdb]
GO
/****** Object:  UserDefinedFunction [dbo].[fun_getPY]    Script Date: 05/23/2012 18:03:45 ******/    www.atcpu.com
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
获取汉字的首拼音
如果是非汉字字符
ALTER    function [dbo].[fun_getPY]
    @str nvarchar(4000)
returns nvarchar(4000)
as
begin
  declare @word nchar(1),@PY nvarchar(4000)
  set @PY=''
  while len(@str)>0
  begin
    set @word=left(@str,1)
    --如果非汉字字符,返回原字符
    set @PY=@PY+(case when unicode(@word) between 19968 and 19968+20901
               then (      www.atcpu.com
                            select top 1 PY
                            from
                             select 'A' as PY,N'驁' as word
                             union all select 'B',N'簿'
                             union all select 'C',N'錯'
                     union all select 'D',N'鵽'
                     union all select 'E',N'樲'
                     union all select 'F',N'鰒'
                     union all select 'G',N'腂'
                     union all select 'H',N'夻'
                     union all select 'J',N'攈'
                     union all select 'K',N'穒'
                     union all select 'L',N'鱳'
                     union all select 'M',N'旀'
                     union all select 'N',N'桛'
                     union all select 'O',N'漚'
                     union all select 'P',N'曝'
                     union all select 'Q',N'囕'
                     union all select 'R',N'鶸'
                     union all select 'S',N'蜶'
                     union all select 'T',N'籜'
                     union all select 'W',N'鶩'
                     union all select 'X',N'鑂'
                     union all select 'Y',N'韻'
                     union all select 'Z',N'咗'
                      ) T
where word>=@word collate Chinese_PRC_CS_AS_KS_WS
                   order by PY ASC
                      else @word
                 end)
    set @str=right(@str,len(@str)-1)
  end     www.atcpu.com
  return upper(@PY)
end
调用如下:
[sql]
select dbo.[fun_getPY]('中国人') 首拼
结果:
首拼
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ZGR
希望以上对大家有帮助。
