阅读:2720回复:0
[SQL Server]shp2sqlserver用法简析
更多 发布于:2012-09-04 18:08
官方说明:
http://code.google.com/p/cumberland/wiki/shp2sqlserver
[plain]
shp2sqlserver.exe -h
Usage: shp2sqlserver.exe [OPTIONS]+ "connectionString" "path to shapefile"
Loads a shapefile into Microsoft SQL Server 2008
    www.atcpu.com
example: shp2sqlserver.exe "Data Source=.\SQLExpress2008;Initial Catalog=spatialtest;Integrated Security=true" myshape.shp
Options:
  -s, --srid=VALUE           The Spatial Reference ID (SRID).  If not specified it defaults to -1.
  -g, --geometry_column=VALUE       The name of the geometry column
  -t, --table_name=VALUE     The table name to use
  -k, --key_column=VALUE     The name of the identity column to create for a primary key
  -i, --index                Create a spatial index
  -l, --latlong              Add spatial data as geography type
  -a, --append               Append data.  If not specified, table will be created
  -h, --help                 show this message and exit
  www.atcpu.com
示例:
shp2sqlserver -g="SHAPE" -s="4326" -i "Data Source=.;Initial Catalog=largesite;Integrated Security=false;user id=sa;password=123456;" "D:\data\xyz.shp"
