阅读:2925回复:0
[C++技术]c++哈希表的制作
更多 发布于:2012-09-06 11:33
*  xcl 2012.2.18   *
*  HashTable       *
*  说明:本哈希表采用线性散列处理冲突,哈希函数为素数取模运算*
#ifdef HAVE_CONFIG_H
#include <config.h>
#endif
#include <iostream>
#include <cstdlib>
#include <time.h>
using namespace std;
#define add_scope 11    //地址范围
int hash(int key)    //处理键值
    return (key*3)%11;
typedef int KeyType,ValType,StatusType; //定义类型
//实际数据结构-----------------------------
typedef struct{
    KeyType    key;
    ValType val;
    StatusType stat;
}Element;
//实现类------------------------------------
class MyList
    public:
    MyList(int n);
    ~MyList();
    public:
    void SetKey(int key,int val);
    void DeleteKey(int key);
    int SearchKey(int key);
    int GetMapSize();
    void ShowList();
    private:
    Element *elem;
        int     hash_size;
        int     dataNum;
MyList::MyList(int n)
    hash_size = n;
    elem = new Element();
    dataNum = 0;
    for(int i=0;i < n;i++)
            elem.key = 0;
            elem.val = 0;
            elem.stat = 0;
MyList::~MyList()
    delete[] elem;
void MyList::SetKey(int key,int val)
    int pos;
    if(hash_size==dataNum)
        cout << "OverFlow~~~~" <<endl;
    pos=hash(key);
    for(int i=0;i<hash_size;i++)
        if(elem[pos].stat == 0)
            elem[pos].key=key;
            elem[pos].val=val;
            elem[pos].stat=1;
            dataNum++;
            cout << "KeySet Success!  "<<elem[pos].key<<"\t"<<elem[pos].val<<"\t"<<pos <<endl;
            return;
        else
            pos=(pos+1)%hash_size;
    cout << "Insert Key Failed~~" <<endl;
int MyList::SearchKey(int key)
    int pos = hash(key);
    int stat = elem[pos].stat;
    int num=1;
    while(stat!=0 ;; num<dataNum)
        if(elem[pos].key == key)
            return pos;
        else
            stat=elem[pos].stat;
            num++;
    return hash_size;    //防止冲突
void MyList::DeleteKey(int key)
    int pos=SearchKey(key);
    if(pos==hash_size)
        cout << "Cannot found the key! Please check out your insert!" << endl;
    else
        elem[pos].key=0;
        elem[pos].val=0;
        elem[pos].stat=0;
        dataNum--;
        cout << "Delete Success~~" <<endl;
int MyList::GetMapSize()
    return dataNum%hash_size;
void MyList::ShowList()
    if(dataNum == 0)
            cout<<"The Table is NULL"<<endl;
            return;
    cout << "There are "<< dataNum <<" nums in the HashTable!" << endl;
    cout<<"************HashTable****************"<<endl;
    cout<<"key             value          position"<<endl;
    for(int i = 0; i<hash_size;i++)
            if(elem.stat == 0)
            continue;
            else
                    cout<<elem.key<<"\t\t"<<elem.val<<"\t\t"<<i <<endl;
    cout<<"***************************************"<<endl;
//获取随即的key与val www.atcpu.com---------------------------------
void GetRdmKey(int *key)
    srand((unsigned)time(NULL));
    for(int i=0;i<6;i++)
        key=rand()%90+10;
void GetRdmVal(int *val)
        val=rand()%900+100;
int main(int argc, char *argv[])
    char flag;
    int inKey,inVal,delKey;
    //初始化部分随机数据
    int *key,*val;
    key=(int*)malloc(6*sizeof(int));
    val=(int*)malloc(6*sizeof(int));
    GetRdmKey(key);
    GetRdmVal(val);
    //写入哈西表
    MyList *list=new MyList(add_scope);
    cout << "Inatiating the HashTable Randomly......" <<endl;
    sleep(1);
    cout << "Result\t\t Key\tValue\tPosition\t"<<endl;
        list->SetKey(key,val);
    do
        //选择操作项
        cout << "\n/*chose the operate*/"<<endl;
        cout <<"Q:exit. I:insert. D:delete. Show."<<endl;
        cin >>flag;
        if(flag=='Q'||flag=='q')
            exit(1);
            else if(flag=='D'||flag=='d')
                cout <<"please insert the key you want del:";
                cin >> delKey;
                list->DeleteKey(delKey);
                else if(flag=='I'||flag=='i')
                    cout <<"please insert the new Key and new Value:";
                    cin >> inKey >> inVal;
                    list->SetKey(inKey,inVal);
                    else if(flag=='S'||flag=='s')
                        system("clear");
                        list->ShowList();
    }while(1);
以上代码在linux平台下,kdevelop环境中编写,测试通过。
