阅读:6412回复:0
[C++技术]用mfc制作程序启动logo
更多 发布于:2012-09-06 11:33
完了,这次土鳖了,介绍个非常过时的东西,其实就是自己收藏一下,怕以后想用的时候自己忘了。
直接进入正题,首先用ps等工具做一个自己喜欢的程序启动的logo位图,我这里制作的logo大小为500*313,比例为黄金比例,看上去很舒服。
新建mfc工程,把制作好的logo位图添加的资源中去,资源ID号设置为IDB_SPLASH。
新建类CSplashWnd,
[cpp]
#pragma once
#include "afxwin.h"
class CSplashWnd :
    public CWnd
public:
    CSplashWnd(void);
    ~CSplashWnd(void);
    CBitmap m_bitmap;
    static void ShowSplashScreen(CWnd* pParentWnd = NULL);
protected:
    BOOL Create(CWnd* pParentWnd = NULL);
    static CSplashWnd* c_pSplashWnd;
public:
    DECLARE_MESSAGE_MAP()
    afx_msg int OnCreate(LPCREATESTRUCT lpCreateStruct);
    afx_msg void OnPaint();
    afx_msg void OnTimer(UINT_PTR nIDEvent);
为各成员函数添加代码:
[cpp]
#include "StdAfx.h"
#include "SplashWnd.h"
#include "resource.h"
CSplashWnd* CSplashWnd::c_pSplashWnd;
BEGIN_MESSAGE_MAP(CSplashWnd, CWnd)
    ON_WM_CREATE()
    ON_WM_PAINT()
    ON_WM_TIMER()
END_MESSAGE_MAP()
CSplashWnd::CSplashWnd(void)
/*: c_pSplashWnd(NULL)*/
CSplashWnd::~CSplashWnd(void)
void CSplashWnd::ShowSplashScreen(CWnd* pParentWnd)
    c_pSplashWnd = new CSplashWnd;
    if (!c_pSplashWnd->Create(pParentWnd))
        delete c_pSplashWnd;
    else
        c_pSplashWnd->UpdateWindow();
BOOL CSplashWnd::Create(CWnd* pParentWnd)
    if (!m_bitmap.LoadBitmap(IDB_SPLASH))   /*加载位图资源,需在资源文件中添加*/
        return FALSE;
    BITMAP bm;
    m_bitmap.GetBitmap(;bm);
    return CreateEx(0,
        AfxRegisterWndClass(0, AfxGetApp()->LoadStandardCursor(IDC_ARROW)),
        NULL, WS_POPUP | WS_VISIBLE, 0, 0, bm.bmWidth, bm.bmHeight, pParentWnd->GetSafeHwnd(), NULL);
    return 0;
int CSplashWnd::OnCreate(LPCREATESTRUCT lpCreateStruct)
    if (CWnd::OnCreate(lpCreateStruct) == -1)
        return -1;
    // TODO:  在此添加您专用的创建代码
    // Center the window.
    CenterWindow();
    // Set a timer to destroy the splash screen.
    SetTimer(1, 1000, NULL);                /*设置消隐时间*/
    return 0;
void CSplashWnd::OnPaint()
    CPaintDC dc(this); // device context for painting
    // TODO: 在此处添加消息处理程序代码
    // 不为绘图消息调用 CWnd::OnPaint()
    CDC dcImage;
    if (!dcImage.CreateCompatibleDC(;dc))
        return;
    BITMAP bm;
    // Paint the image.
    CBitmap* pOldBitmap = dcImage.SelectObject(;m_bitmap);
    dc.BitBlt(0, 0, bm.bmWidth, bm.bmHeight, ;dcImage, 0, 0, SRCCOPY);
    dcImage.SelectObject(pOldBitmap);
void CSplashWnd::OnTimer(UINT_PTR nIDEvent)
    // TODO: 在此添加消息处理程序代码和/或调用默认值
    DestroyWindow();
    AfxGetMainWnd()->UpdateWindow();
    CWnd::OnTimer(nIDEvent);
其中消隐时间的设置为你喜欢的数值。www.atcpu.com
接下来,只需在MFC工程中的CMainFrame类中添加函数OnCreate,并在函数定义中添加语句CSplashWnd::ShowSplashScreen(this);
[cpp]
int CMainFrame::OnCreate(LPCREATESTRUCT lpCreateStruct)
    if (CFrameWnd::OnCreate(lpCreateStruct) == -1)
        return -1;
    return 0;
好了,你的程序启动logo做好了,编译运行吧,少年!~~
