阅读:3213回复:0
[C++技术]学习笔记--空类,虚函数类,虚继承类的空间大小
更多 发布于:2012-09-06 11:33
//此代码在32位win下运行成功
#include<iostream>
using namespace std;
class A//A是空类,编译器会用一个char类型标记这个类,大小为1
class B:public A//B继承了A,但同样也是空类,大小为1
class C:virtual public A//虚拟继承的时候编译器会安插一个指向父类的指针,大小为4
class D//大小为4
  public:
  int a;
  static int b;//静态变量被放在静态存储区
class E //print函数不占内存空间,大小为4
    public:
    void print(){cout<<"E"<<endl;}
    private:
    int a;
class F//虚函数会占用一个指针大小的内存,系统需要用这个指针维护虚函数表。大小为8
    public:
    virtual void print(){cout<<"F"<<endl;}
    private:
    int a;
class G:public F//多了一个虚函数内存大小不变,可见一个类只有一个虚函数指针。大小为8
    public:
    virtual void print(){cout<<"G"<<endl;}
    virtual void print2(){cout<<"G2"<<endl;}
int main()
    A a;
    B b;
    C c;
    D d;
    E e;
    F f;
    G g;
    cout<<sizeof(A)<<" "<<sizeof(a)<<endl;//1 1
    cout<<sizeof(B)<<" "<<sizeof(b)<<endl;//1 1
    cout<<sizeof(C)<<" "<<sizeof(c)<<endl;//4 4
    cout<<sizeof(D)<<" "<<sizeof(d)<<endl;//4 4
    cout<<sizeof(E)<<" "<<sizeof(e)<<endl;//4 4
    cout<<sizeof(F)<<" "<<sizeof(f)<<endl;// 8 8
    cout<<sizeof(G)<<" "<<sizeof(g)<<endl;//8 8
    return 0;
