阅读:2775回复:0
[C++技术]设计模式C++描述----19.命令(Command)模式
更多 发布于:2012-09-06 11:35
一. 举例说明
我们知道,在多线程程序中,多个用户都给系统发 Read 和 Write 命令。这里有几点需要说明:
1. 首先明确一点,所有的这些 Read 和 Write 命令都是调用一个库函数。
2. 用户并不需要知道别的用户的存在,也不管别人发不发命令,只管自己发命令,最后给结果即可。
3. 这些命令先是到了一个消息队列里面,然后由消息队列调用库函数。
结构图如下:
代码如下:
[cpp] class Command;
//实施与执行类
class Reciever
public:
    void Action()
        cout<<"Do action !!"<<endl;
//抽象命令类
class Command
public:
    virtual ~Command() {}
    virtual void Excute() = 0;
protected:
    Command() {}
//Read 命令
class Read_Command:public Command
public:
    Read_Command(Reciever* rev)
        this->_rev = rev;
    ~Read_Command()
        delete this->_rev;
    void Excute()
        cout<<"Read Command..."<<endl;
        _rev->Action();
private:
    Reciever* _rev;
//Write 命令
class Write_Command:public Command
public:
    Write_Command(Reciever* rev)
        this->_rev = rev;
    ~Write_Command()
        delete this->_rev;
    void Excute()
        cout<<"Write_Command..."<<endl;
        _rev->Action();
private:
    Reciever* _rev;
//要求命令执行的类
class Invoker
public:
    Invoker(Command* cmd)
        _cmd = cmd;
    Invoker()
    ~Invoker()
        delete _cmd;
    //通知执行类执行
    void Notify()
        list<Command*>::iterator it = cmdList.begin();
        for (it; it != cmdList.end(); ++it)
            _cmd = *it;
          _cmd->Excute();
    //添加命令
    void AddCmd(Command* pcmd)
        cmdList.push_back(pcmd);
    //删除命令
    void DelCmd(Command* pcmd)
        cmdList.remove(pcmd);
private:
    Command* _cmd;
    list<Command*> cmdList;
//测试代码 www.atcpu.com
int main(int argc,char* argv[])
    Reciever* rev = new Reciever(); //定义一个执行类
    Command* cmd1 = new Read_Command(rev);//Read 命令
    Command* cmd2 = new Write_Command(rev);//Write 命令
    Invoker inv; //管理所有命令
    inv.AddCmd(cmd1);
    inv.AddCmd(cmd2);
    inv.Notify(); //通知执行类,执行
    inv.DelCmd(cmd1);
    inv.Notify();
    return 0;
class Command;
//实施与执行类
class Reciever
public:
void Action()
//抽象命令类
class Command
public:
protected:
Command() {}
//Read 命令
public:
  this->_rev = rev;
~Read_Command()
  delete this->_rev;
void Excute()
  _rev->Action();
private:
Reciever* _rev;
//Write 命令
public:
  this->_rev = rev;
~Write_Command()
  delete this->_rev;
void Excute()
  _rev->Action();
private:
Reciever* _rev;
//要求命令执行的类
class Invoker
public:
  _cmd = cmd;
Invoker()
~Invoker()
  delete _cmd;
//通知执行类执行
void Notify()
   _cmd = *it;
    _cmd->Excute();
//添加命令
//删除命令
private:
Command* _cmd;
//测试代码
inv.AddCmd(cmd1);
inv.AddCmd(cmd2);
inv.DelCmd(cmd1);
inv.Notify();
return 0;
二. 命令模式
定义:将一个请求封装为一个对象,从而使你可用不同的请求对客户时行参数化;对请求排队或记录请求日志,以及支持可撤销的操作。
优点:
1. 它能比较容易地设计一个命令队列。
2. 在需要的情况下,可以较容易地将命令记入日志。
3. 允许接收请求的一方决定是否要否决请求。
4. 可以容易地实现对请求的撤销和重做。
5. 增加新的具体命令类很容易
6. 把请求一个操作的对象(Command)与知道怎么执行一个操作的对象(Receiver)分割开来。
作者 lwbeyond
