阅读:3658回复:0
[C++技术]设计模式C++描述----16.状态(State)模式
更多 发布于:2012-09-06 11:35
一. 举例
一般汽车发动机工作时有四种状态,吸气、压缩、做功和排气。
在运行时,不同的状态会有不同的行为,当前的状态机在适当的时候会过渡到下一状态。
其实用户在使用时根本不知道当前的状态,也无需知道当前的状态。用户只需要给发动机一个初始状态,最后得到一个停止状态就行了。
结构图如下:
代码如下:
[cpp]//状态
class State
public:
    virtual void Operation(Work *work) {}
//工作
class Work
private:
    State *m_state;  //目前状态
    int m_step;      //步骤
public:
    Work(State *state): m_state(state), m_step(0)
    ~Work()
        delete m_state;
    int GetStep()
        return m_step;
    void SetStep(int step)
        m_step = step;
    void SetState(State *state)
        delete m_state;
        m_state = state;
    void Operation()
        m_state->Operation(this);
//排气状态
class ExhaustState: public State
public:
    void Operation(Work *work)  //排气操作
        if(work->GetStep() == 4)
            cout<<"Step : "<<work->GetStep()<<"排气操作"<<endl;
//做功状态
class ActState: public State
public:
    void Operation(Work *work) //做功操作
        if(work->GetStep() == 3)
            cout<<"Step : "<<work->GetStep()<<"做功操作"<<endl;
        else
            work->SetState(new ExhaustState());
            work->Operation();
//压缩状态
class CompressState: public State
public:
    void Operation(Work *work) //压缩操作
        if(work->GetStep() == 2)
            cout<<"Step : "<<work->GetStep()<<"压缩操作"<<endl;
        else
            work->SetState(new ActState());
            work->Operation();
//吸气状态
class InhaleState: public State
public:
    void Operation(Work *work) //吸气操作
        if(work->GetStep() == 1)
            cout<<"Step : "<<work->GetStep()<<"吸气操作"<<endl;
        else
            State *p = new CompressState();
            work->SetState(p);
            work->Operation();
//测试代码
int main()
    State* st = new InhaleState(); //初始状态
    Work *work = new Work(st);
    for(int i = 1; i < 5; ++i)
        work->SetStep(i);
        work->Operation(); //操作
    delete work;
    return 0;
//状态 www.atcpu.com
class State
public:
//工作
class Work
private:
    int m_step;      //步骤
public:
    ~Work()
        delete m_state;
    int GetStep()
        return m_step;
        m_step = step;
        delete m_state;
        m_state = state;
    void Operation()
//排气状态
public:
//做功状态
public:
        else
            work->Operation();
//压缩状态
public:
        else
            work->Operation();
//吸气状态
public:
        else
            work->SetState(p);
            work->Operation();
//测试代码
int main()
        work->SetStep(i);
    delete work;
    return 0;
二. 状态模式
定义:允许一个对象在其内部状态改变时改变它的行为。对象看起来似乎修改了它的类。
结构图:
使用范围:
(1)一个对象的行为取决于它的状态, 并且它必须在运行时刻根据状态改变它的行为。(上面的例子就是这种情况)
(2)一个操作中含有庞大的多分支的条件语句,且这些分支依赖于该对象的状态。
