阅读:2998回复:0
C 语言弹出光驱代码
更多 发布于:2012-09-06 12:30
* Eject CDs
#include <windows.h>
#include <winioctl.h>
#include <stdio.h>
#include <stdlib.h>
/* options */
static int unmount_only;
static int eject_all;
/* wrapper for GetDriveTypeW */
static Dword get_drive_type( WCHAR drive )
    static const WCHAR rootW[] = {'a',':','\\',0};
    WCHAR path[16];
    memcpy( path, rootW, sizeof(rootW) );
    path[0] = drive;
    return GetDriveTypeW( path );
static BOOL eject_cd( WCHAR drive )
    static const WCHAR deviceW[] = {'\\','\\','.','\\','a',':',0};
    PREVENT_MEDIA_REMOVAL removal;
    WCHAR buffer[16];
    HANDLE handle;
    Dword result;
    if (get_drive_type( drive ) != DRIVE_CDROM)
        printf( "Drive %c: is not a CD or is not mounted\n", (char)drive );
        return FALSE;
    memcpy( buffer, deviceW, sizeof(deviceW) );
    buffer[4] = drive;
    handle = CreateFileW( buffer,
                          GENERIC_WRITE | GENERIC_READ,
                          FILE_SHARE_READ|FILE_SHARE_WRITE,
                          NULL, OPEN_EXISTING, 0, 0 );
    if (handle == INVALID_HANDLE_VALUE)
        printf( "Cannot open device for drive %c:\n", (char)drive );
        return FALSE;
    printf( "ejecting %c:\n", (char)drive );
    if (!DeviceIoControl( handle, FSCTL_LOCK_VOLUME, NULL, 0, NULL, 0, ;result, NULL ))
        printf( "FSCTL_LOCK_VOLUME failed with err %d\n", GetLastError() );
    if (!DeviceIoControl( handle, FSCTL_DISMOUNT_VOLUME, NULL, 0, NULL, 0, ;result, NULL ))
        printf( "FSCTL_DISMOUNT_VOLUME failed with err %d\n", GetLastError() );
    removal.PreventMediaRemoval = FALSE;
    if (!DeviceIoControl( handle, IOCTL_STORAGE_MEDIA_REMOVAL, ;removal, sizeof(removal), NULL, 0, ;result, NULL ))
        printf( "IOCTL_STORAGE_MEDIA_REMOVAL failed with err %d\n", GetLastError() );
    if (!unmount_only)
        if (!DeviceIoControl( handle, IOCTL_STORAGE_EJECT_MEDIA, NULL, 0, NULL, 0, ;result, NULL ))
            printf( "IOCTL_STORAGE_EJECT_MEDIA failed with err %d\n", GetLastError() );
    if (!DeviceIoControl( handle, FSCTL_UNLOCK_VOLUME, NULL, 0, NULL, 0, ;result, NULL ))
        printf( "FSCTL_UNLOCK_VOLUME  failed with err %d\n", GetLastError() );
    CloseHandle( handle );
    return TRUE;
/* find the CD drive, and die if we find more than one */
static WCHAR find_cd_drive(void)
    WCHAR ret = 0, drive;
    for (drive = 'c'; drive <= 'z'; drive++)
        if (get_drive_type( drive ) != DRIVE_CDROM) continue;
        if (ret)
            printf( "Multiple CD drives found (%c: and %c:), you need to specify the one you want.\n",
                          (char)ret, (char)drive );
            exit(1);
        ret = drive;
    return ret;
static void usage(void)
    printf( "Usage: eject [-u] [-a] [-h] [x:]...\n" );
    printf( "    -a  Eject all the CD drives we find\n" );
    printf( "    -h  Display this help message\n" );
    printf( "    -u  Unmount only, don't eject the CD\n" );
    printf( "    x:  Eject drive x:\n" );
    exit(1);
static void parse_options( int *argc, char *argv[] )
    int i;
    char *opt;
    for (i = 1; i < *argc; i++)
        if (argv[0] != '-')
            /* check for valid drive argument */
            if (strlen(argv) != 2 || argv[1] != ':') usage();
            continue;
        for (opt = argv + 1; *opt; opt++) switch(*opt)
        case 'a': eject_all = 1; break;
        case 'u': unmount_only = 1; break;
        case 'h': usage(); break;
        default:
            printf( "Unknown option -%c\n", *opt );
            usage();
        memmove( argv + i, argv + i + 1, (*argc - i) * sizeof(*argv) );
        (*argc)--;
        i--;
int main( int argc, char *argv[] )
    parse_options( ;argc, argv );
    if (eject_all)
        WCHAR drive;
            if (!eject_cd( drive )) exit(1);
    else if (argc > 1)
        int i;
        for (i = 1; i < argc; i++)
            if (!eject_cd( argv[0] )) exit(1);
    else
        WCHAR drive = find_cd_drive();
        if (!drive)
            printf( "No CD drive found\n" );
            exit(1);
    exit(0);
