阅读:2583回复:0
求最大子序列和
更多 发布于:2012-09-06 12:30
#include<stdio.h>
#include<stdlib.h>
#include"random_n.h"
#define MAX_NUM 100
*Function:the most powerful method to solve the problem
*Huge:T = O(N)
*Author:Qinzhiguo
*Date:2012-1-30
int MaxSubSum_HighSpeed(int a[],int N)
int ThisSum,MaxSum,i,j;
ThisSum=MaxSum=0;
for(i=0;i<N;i++)
ThisSum += a;
if(ThisSum > MaxSum)
MaxSum=ThisSum;
else if(ThisSum <0)
ThisSum=0;
return MaxSum;
*Function: Max3 is a method to get the biggest one of 3 input numbers
*Author:Qinzhiguo
*Date:2012-2-3
int Max3(int a,int b,int c)
if(a>=b ;; a>=c)
return a;
else if(b>=a ;; b>=c)
return b;
else if(c>=a ;; c>=b)
return c;
else
return -1;
*Function:a recursive method to get the sub maxmimu sum of the sequence
*Author:Qinzhiguo
*Date:2012-2-3
int MaxSubQuenceSum(int a[],int left,int right)
int MaxLeftSum,MaxRightSum;
int MaxLeftBorderSum,MaxRightBorderSum;
int LeftBorderSum,RightBorderSum;
int center,i;
if(left == right)
if(a[left] >0)
return a[left];
else
return 0;
center = (left + right) / 2;
MaxLeftSum=MaxSubQuenceSum(a,left,center);
MaxRightSum=MaxSubQuenceSum(a,center+1,right);
MaxLeftBorderSum=0;
LeftBorderSum=0;
for(i=center;i>=left;i--)
LeftBorderSum += a;
if(LeftBorderSum > MaxLeftBorderSum)
MaxLeftBorderSum=LeftBorderSum;
MaxRightBorderSum=0;
RightBorderSum=0;
for(i=center+1;i<=right;i++)
RightBorderSum +=a;
if(RightBorderSum > MaxRightBorderSum)
MaxRightBorderSum=RightBorderSum;
return Max3(MaxLeftSum,MaxRightSum,MaxLeftBorderSum+MaxRightBorderSum);
*Function:get the maxsubsum by giving the argments input.
*Author:Qinzhiguo
*Date:2012-2-3
int MaxSubSum(int a[],int n)
return MaxSubQuenceSum(a,0,n-1);
*Function:Main indoor of the whole project
*Author:Qinzhiguo
*Date:2012-1-31
int main()
int a[MAX_NUM];
int i=0,MaxSum=0;
while(i<MAX_NUM)
a=0;
i++;
random_n(a,MAX_NUM);
MaxSum = MaxSubSum(a,MAX_NUM);
i=0;
while(i<MAX_NUM)
printf("%d ",a);
i++;
printf("\nThe List MaxSubQueneSum is %d\n",MaxSum);
if(i==0)
printf("\nNothing is done!\n");
else
printf("\n------------Program Finshed------------\n");
return 0;
头文件包含的random.h是我自己写的一个产生随机数的函数,大家可以自己实现,或者参考我之前博客中给出的生成随机数的方法。
这样在测试的时候具有比较大的优势,减去了大数据量的输入负担。
